ABS/Skid control module, any insight?
Bijan
Hey dudes
2002 sr5
210k miles
Symptoms: ABS, Brake, VSC off, VSC trac lights are all on. No CEL. Speedo + everything works. Only 2 times I've hit the brakes and heard a failing pumping sound - with my rig not stopping like it should.
I've had it diagnosed by a Toyota certified mechanic. His insight is to replace the entire ABS / VSC control module. The unit that sits under/behind the brake fluid reservoir.
New part is over $1800
YodaJim / Ebay have it for around $450-500
Does anyone have experience with this issue and did this potential remedy fix your problem? THX
I had this happen to me and it was the vsc trac skid control module/ecu.
quick easy fix!
01 and 02 only had these.
did you do a zero point calibration of the yaw rate sensor or buy a new vac/trac ECU????
I misunderstood your post as you stated the speedometer works, Yes it could very well be the brake module assembly.
I have a known good one if you can't find one.
how much>?,,,,
everything was fine until i had an alignment of my truck and thats when those two lights came on.....
I'd try a lot of things before replacing that module. Zero point for starters.
this is my whole dilemma !!!
i have tried the zero point many times...
i doubt its the module as everything was fine until after an alignment...
but the calibration never works,,,,
sad times
sad times
I'm guessing you followed the wrong tutorial. There is a tutorial out there that only gives you half the steps needed to properly zero point. Refer to your FSM for the proper procedure. I had the same issue until after I did this.
I have the same issue as you do (ABS, Brake, VSC off, VSC trac lights are all on).
Mechanic told me to change the ECU. However, the codes came back as speed sensor problem.
Took both front speed sensors out and cleaned them. Code keeps coming back.
A buddy told me to check that speed sensors are not loose or damaged.
I have not had the time to do that yet. I will check that first and then do a zero point calibration.
These are the instructions I have found on how to do it:
https://mike-thomson.com/blog/?p=1143
01-02 4Runner How to Zero Point Calibrate your VSC system. - YotaTech Forums
Maybe someone can chime in and let us know if these are correct or not.
Ruff
Ruff
That's the link I figured you'd follow. Here's the correct procedure. Follow and report back.
Zero Point
I got a scanguage ll and LOVE it, but there are probably better options now. If you just want a scanner, I see them all the time on newegg.com for cheap.
MaximussK
