Absalom's Build Thread #2 - Revenge of the Oil Burners
Despite the intense oil burner smoke screen while wheeling it, I rather liked the LC he had.
I believe one of the injectors needed cleaning, it should not have been that smokey. I agree, amazing truck.
Do you happen to know if ACME has an adapter kit for the V6 R150f to the 1.9 TDI motor? I am working on my swap at the moment and that's the crucial part to this. 22-re plate isn't an option (running drivers side diff) and the R151 Bellhousing is ridiculously hard to find. Thanks man. I hope to see your diesel build come to fruition as well. For myself, doing the 4wd swap at the same time as the TDI over doing a turbo on the 3rz and then doing the swap, totally worth the money. I would have spent more money on the 3rz vs the TDI because I need a new trans either way, why not put money where it counts and get an already stellar turbo setup?! Winning!
Yes! Acme does offer a V6 kit! Which motor are you doing? I'm going to actually run an automatic when I start the project behind a BEW. Keep me posted with your details!
So do we ever actually get to see proof that this new 4runner exists? Cause I mean your last diesel conversion was soo amazing...
Glad your back.
Glad your back.
*you're
It very much exists, but I learned my lesson about being a big fat liar last time, so I'm not posting crap until it's finished this time. I'm doing a full build thread on a private server so I don't forget anything, and then when it's finished I'll copy here.
I'm just messing with you. I really am glad you're back but I singe think you ever really left. I hope you have fun with the new 4runner and Colorado.
Good way to go with the private server. Should be a good read.
*you're
Sweet, another swap!! I just sent you a pm.
I am going to run the ALH. I can't seem to find any AHU engines. I just received an email from the guys over at ACME on the buying process for the v6 adapter kit and I'll be buying it here in a couple weeks! Again, I am planning on running a 1.9 TDI-M (Manual injector pump) in order to bypass a lot of the ECM wiring and tap into my wiring harness only at crucial points. I would like to keep all of my factory electronics and I am talking to a gentleman names [MENTION=83391]jimbote[/MENTION] or something close to that, over on the TDI forum. Just registered over there. I am already 5 speed so it makes sense to keep it that way. I'll be running the 3.4l clutch and flywheel. Www. Car-part.com has been an excellent resource for me to find trans. Parts. Manual injector pump is a must for me and I've found several motors with them! I feel that motor mount fab is probably one of the easier factors in this swap. I was utterly confused when I was on ACME's website unable to find the v6 adapter, but they reassured me that they've got them. [MENTION=79826]absalom[/MENTION] let me know if you want links to all of the V6 builds they have as references, they gave me lists of threads including all of the best work they've seen with their adapters.
I highly recommend sticking with electronic control. M-tdi is a massive step backwards in technology. You lose all the flexibility of electronic tuning, monitoring, etc. You also lose VNT turbo, which IMO is mandatory on offroad vehicles for that low down, instant torque. You lose the phenomenal OEM reliability that the ALH is known for. And finally, you lose 50 state legality by not keeping it factory and losing EGR.
All it takes to retain factory electronics is a simple $50 immobilizer delete. Don't want to wire the rest yourself? Do what I'm doing and have Fast-forward automotive build you a complete, plug n' play, standalone harness.
Mechanical injection is NOT more reliable, but it is less economical, less powerful, and much less flexible. My Land Cruiser was mechanical direct injection, after a year with it, I much preferred interacting with the TDI computer via VCDS.
Finally, the ALH is undoubtedly the best diesel ever produced by VW, if not anyone. It's stupid reliable, has a much better power band than the AHU, and has an unmatched level of aftermarket support. The only reason I am running the BEW is because I'm after a very quiet swap. The BEW is admittedly quieter and smoother than the ALH, and also has more headroom for my power goals. I'm shooting for a cold 170/305 at the wheels, with full torque at 1,800. ALH can hit those numbers, but will churn out higher EGT's in the process. I'll still probably run meth injection, but I am pretty sure the BEW won't need it unless I'm climbing from 8,000-11,000 feet nonstop.
So essentially there is a company making your harness? What is that running you? You've made me reconsider the Electronic injection atleast. It would be nice to run VCDS. Let me take a look at the immobilizer delete. Could you shoot me the price of your harness? (P.S. I hope to have this project completed in a span of 9 months, between October and next July. I am driving out to CO in the 4runner, we absolutely MUST meetup to get together as two TDI 4runners. What'ya say?)
It's less than the cost of your manual IP, and about 1000x easier to install. Text me your email address and I'll shoot you over the detailed proposal they sent me.
303.746.9938
Sent from my SM-G920V using Tapatalk
Do you have a larger pic? I can't count the bugs in your radiator....:D
PS, You look good for 96, what's your secret?
pax at 4
