Adjusting OW Front Settings
phillyd2
Senior Member
Posting for reference only:
Looking from top down (hood to ground) you rotate the collars counter clockwise to loosen the locking collar and also to adjust the ride height down on the adjustment collar.
The way that works the best to adjust the coilovers are to first measure the fenders on level ground on both sides. Then adjust the passenger side all the way to the top (lowest height). Drop the truck, drive it in and out and then measure the driver and passenger side. If the driver side is taller than passenger side. Raise truck measure the thread showing on driver side. Reduce the amount of thread by 1/2 of the difference in fender height between driver and passenger side. Drop truck drive in and out, and measure again. It sounds complicated but really easy when you actually do it, it will make a lot more sense once you start doing it.
To adjust the coilovers both front wheels need to be drooped completely. There is no need to remove the wheels. Use the hook wrench to loosen the top lock collar of the adjustment ring. Using the hook wrench rotate the adjustment collar down for additional lift or up for less lift. The lift will be approximately double the distance the collar is moved. Once the desired lift is reached tighten the lock collar on the adjustment collar again. Tip:‐ Using some lubrication on the thread and collar will make it easier to adjust. DO NOT adjust the collar beyond 1” of exposed thread between the top of the collar and the bottom of the top shock cap.
Below from OW 2.5 with LR UCA installed on 2011 Limited
Top cap = Red
Locking Collar = Blue
Adjustment Collar = Yellow
OWDriverArrow.jpg~original
Great detailed post.
Please note this is for 2.5 COs. The 2.0s are different in the amount of thread showing.
Also typically the driver side is heavier, and will be a bit lower at the same CO setting (thus requiring a bit more adjustment and thread showing once leveled). This depends on individual 4Runners, how much adjustment is required.
This may be a silly questions but how do you adjust the rear shocks? I have looked through the OW installation instructions and searched here but don't see it.
I had the kit installed last fall with my stock sized Duratracs by Slee down in Golden but didn't have it raised to its full height. Now that I am taking off my Nokian snows (stock size) I am going to put on some 285/70/17 Duratracs and will need to raise the suspension a bit so that it all fits.
Due to my location I am having Big O do it here locally (rather than driving down to the front range) but I am fully expecting that I will need to give them more direction on how to raise the suspension and haven't had any luck with the rear.
And last but not least - I have done searches but haven't had any luck figuring out what the right height I should set it at to accomodate the new tire size. Do I need to go to the max height or will something less be better?
Ummmm....the rears are NOT adjustable. If you want more height get a different rear spring.
Jesse1
