ddicosmo
I have a 2008 SR5 v6 4x4 T4R with 35,000 and just greased the shafts and changed the rear differential fluid (I sitll need to do the front diff and transfer case). While I was under the vehicle, I was wondering what else needs to be lubed and greased. Is there a post that shows what else besides the driveshaft needs to be lubed? For example, there are a lot of linkage connections for the suspension that seem like they should be lubed. Also, there are a lot of rubber connectors (for example, the rubber hangers for the exhaust system) as well. Should these rubber pieces get lubed as well? If so, what should I use to lube these rubber pieces?
Basically, I'm looking for the following info. as this is the first time doing this:
- Which rubber gaskets, hangers, and connectors require lubing? Also, what product to use for this?
- What needs to be lubed for the suspension pieces? What product to use for this?
- is there anything else besides the driveshaft that has zerk fittings and requires grease?
- Finally, is there anything in the engine compartment or other part of the vehicle that requires greasing?
Thanks for the info.
