Aftermarket 6.5 Inch Speaker Adapters (rear doors)
dpr422
I have searched high and low on T4R.Org to see if anyone has found some good aftermarket speaker adapters (6.5 in) for the rear doors on a 5th Gen TE. Yes, I can try to make my own out of MDF, but admittedly I am no 'Norm' from 'This Old House'. The easiest route would be to just buy them.
Does anyone know of any good aftermarket products? (not including TacoTunes)
I would be putting in some JL C2 -- I would rather do this myself then pay $100 bucks for an installer to do it...
(also, any suggestions on a good, but not overly expensive line converter? I plan to add an amp, but keep the OEM HU)
I think I am going to try the Scosche SAT6... If this does not work, I will bite the bullet and try to build them... Low risk at $10
On Tacotunes, I do have a set of their adapters for the front... I bought them 3 years ago for an FJ that I traded in... They are nice, but expensive. With shipping I think the cost was around $40 for the pair...
Here is an update... the Scosche adapter will match up with holes on rear doors, but if you buy these, double check the size of the speakers that you plan on installing. In my case, I installed JL C2 6.5 in.... I had to drill holes in the adapter before mounting to the doors. Also, they are made of really cheap plastic... Not sure if they will last, but I'll find out..
goddesszilla
