Aftermarket Stereo Problem
Aerials
I ran into some problems after installing an aftermarket stereo and was wondering if anyone had any ideas..
I decided one day i wanted to upgrade the sound in my '97 4wd 4runner, i removed the stock head unit, stock amp behind the head unit, cheap add on 10 cd changer that was someone added before me and was having issues to i decided just to get rid of it. I installed a sony xplod head unit with built in 52x4 outputs that go to the factory speakers. I also added an amp with 2 12s subs in the back. So after i got everything working it seemed to be working fine. The headlights dim only a small bit with loud bass sections and the head unit doesnt dim or do anything weird with heavy braking. It seemed to be working fine and i left to go back to college and i cant bring it with me at the moment :(.
But my problem is that a few days later the car wouldn't start. So a family member was stuck at work for awhile, but after she waited for help, she tried again later, and it started. I disconnected the amp from the battery thinking that it might have somthing to do with the large drain the subs and amp would have on it. (Amp is seperatly powered then head unit via 4guage cable to battery) Next day, had the same problem wouldnt start, then later it strangely starts up. Anyway i disconnected the head unit and afterwards the car starts normally, just without any music at all. It might also be unlocking and locking randomly while driving or thats what ive been told while the head unit is on.
So im thinking i might have to do a seperate power line to the head unit or something? Anyone experience anything similar to this?
How old is your battery? When you installed the deck did you be sure to tie up ALL loose wires? Is the deck powering off when the truck is off? Just a few places to start checking... Happy hunting bro!!!
the battery is fairly new, less then a year old. I tied up all the lose wires with electrical tape but i will probly double check that soon
The deck does turn off, but has a feature when you leave it beeps at you if you leave the faceplate on after u leave. It only beeps 3 or so times then stops
check your battery wires? might be loose. shouldnt be your stereo. did you buy a stereo harness or did you splice up the stock wires?
hmm... it def. sounds like there is a drain on the battery, maybe a loose wire grounding out, the only place i could imagine would be wherever the cd changer was wired up... Did you use like an adapter for the radio? ( one that plugs into the factory radio harness )
spliced the wires, didnt think to buy the harness until i was already installing, the new head unit didnt use all of the wires the stock one used tho
ill soon check to see if any of the wires are grounding out,if any of them came lose or somthing, but the cd changer were spliced out from the main power to the old stereo so i cut them off and taped it up
thanks for the help guys
keep us posted to your findings, that's all i can think of to check... be sure that your battery terminals are clean and tight...
