There is no jack per se like "video in"video out" jacks. It's hardwired thru connectors.It's a connector that attaches to the camera itself in the back liftgate and is wired thru the connector that attaches to the mirror or Nav. You will have to read the wiring diagrams to pin it out and find which wire color is what.
Nobody that I know of has done it.Let us know if you do.
Thanks to Nashman69g who did the legwork of acquiring all the 2010 4runner manuals and it's in there. http://www.toyota-4runner.org/5th-gen-t4rs/65237-tis-fsm-2010-4runner-here.html
No , you can't put a OEM nav in a SR5. It's not wired for it.Hi Harper7
Do you think that I can install this on my SR5 since i wanted original screen?
Can I use for backup camera screen too?I don;t know about the wiring for the sr5 for the camera.Thanks.
2010 4Runner JBL Headunit: eBay Motors (item 300462241769 end time Sep-07-10 10:56:26 PDT)
Read this thread........ http://www.toyota-4runner.org/5th-gen-t4rs/70394-factory-nav-unit-pictures.html#post600634
The GPS antenna is actually under the dash, I believe.I've searched high and low on the internet and have canvassed this forum for days searching for a few answers and haven't been lucky - so here goes:
I just had a Pioneer AVIC-120BT installed in my TE today. It has the Pioneer XM module with it. Good news, nearly everything works great (bluetooth/ipod/radio/navigation), bad news - XM works for about 6" then breaks up. It's horrible. My good friends at Best Buy mounted the XM and GPS antenna above the head unit. I had asked them to figure out a way to use the factory shark fin but that was impossible, so I am told. The GPS seems to work with no problem. I am philosophically opposed to having a shark fin with no purpose on the truck! So...
1) Has ANYONE been able to use the shark fin antenna with the aftermarket Pioneer container, if so, how?
2) If you haven't been able to use that - where are you putting your antenna? I'm in Las Vegas so I'm not exactly off the beaten path for the satellites - nonetheless, I get no reception.
3) If you mounted your antennas outside the interior, did anybody fully removed the shark fin (SeattleMike, I know you pulled it off and put it back on)? What'd you fill the likely hole with? How do you get it off?
I am waaay frustrated over this whole thing and really appreciate any and all words of advice. Thank you in advance for your time/pearls of wisdom.
Mike
Hey guys,
Thought I'd share this tip...I just found the Pioneer AVIC-Z120BT for super cheap on Amazon using code:VRCBKCX6
*Note this code is good for 30% off on all pioneer products bought from amazon as the merchant
So the head unit comes down to 906.50 - 100 mail in rebate = $806.50!
resurrection!
When replacing the stereo, does the wire harness for the OEM stereo have leads for all 8 speakers or is the split somewhere hidden underneath the dash somewhere? My audi has 5 speakers and the center channel is wired to the other speakers right at the harness behind the stereo.
I'm seriously considering adding a JBL MS-8 which time corrects and EQ's up to 8 channels, perfect for the 8 speakers in the car (I won't be adding a sub for space constraints) along with an aftermarket head unit.
Thanks.
Hey guys,
I just tried the code...it won't accept it...they list the price for the HU as $1097 before rebate...I wonder what gives with these coupon codes?
The code didn't work for me. It would be enough for me to pull the trigger. When did you buy it?
You have to use it on the one actually buying from Amazon.....not one of their vendors.
Not the one for $1097 Click on "4 new" and at amazon it's $1295. Then the code apllied gives you 30% off that!
I just tried it and it would work for me.
Great Nav at that price or check out the Avic x920bt ,almost same thing smaller screen.
I paid $1050 4 months ago when they came out....:bash:
I did select Amazon as seller originally but didn't work. Oh well should wait anyway.
