DesertCanyons
Airbag replacement tomorrow
Tomorrow I'm having the airbag replaced tomorrow by the dealer here in Pasadena. I will be inspecting the dash and photographing the dash completely, including any existing scratches before I take it in.
Yesterday I took the RCI skid plates off because I don't want them messing that up. Last year I had the "Free Oil Change" done by the dealer and they must have used an impact wrench to overtighten the skid plate bolts. I had to cut the OEM skid plate off to work on the suspension. And the front left bolt is stripped now so I need to tap it and replace the bolt with a slightly larger one.
The transmission is also making noise so they will be checking that under warranty too. The trans rattles when warm, in drive when I come to a stop while stepping on the brake. It stops as soon as I put it in neutral. I found a place where the cross-under cat-back exhaust pipe was rubbing on the skid plate so that may actually be the problem with the noise. And if so, somehow putting it in neutral stops the rattle. I may need to shim the skid plates a bit?
