Airbag recall question
K9trainer
I have a 2015 TEP and like everyone’s else need the passenger side airbag replaced under the recall.
Is it true the entire dash has to come off for the replacement?
I’m not happy about have any work done on a newer truck, it’s just never the same because of the work quality. What should I expect with this repair?
As a mercedes benz tech, the most we have to do for passenger airbags is remove the glove box. Some C classes we just loosen the passenger side of the dash to give it a bit of wiggle for it to fall out. Hopefully its a simple process with the 4runner. How long are they quoting you for a wait time? I think if its more than 2 hours (car wash time not included) they dash is probably coming off.
Had mine done yesterday and they took the dash and most of the center console out. They had to have me come back in and unlock my console vault so they could remove it. Originally they said it would be a 2 hour job, was more like 6.
What exactly is the reason for this recall? Depending on the reason, I may or may not have it done.
I had it done over a year ago. Car is stil solid and rattle free.
In an accident the airbag can shoot out schrapnel and injury or kill your passengers. People have died due to this issue in low speed accidents.
I have life insurance on the wife...……. lol in all seriousness, thanks for the clarification. Not 100% sure my 16 made the list yet, haven't run the VIN but I will get it taken care of for sure.
One more data point: I scheduled mine yesterday ('11 Trail) and when I said I was dropping it off the night before the the rep said "great, this isn't a job you'll want to wait for - it'll be at least 3 hours"
Yeah I don't expect it to be fast and sadly I expect issues to come from it because most dealer mechanics are terrible at what they do. I plan to photograph all plastics before it goes it purely to cover my hind parts in the event they scratch or damage something. My 2016 just rolled 15K miles, it's spotless. better than showroom condition with the way I detail my vehicles, still has the new car smell and I plan on keeping it that way.
Good idea. My shifter was gouged after and the dealer replaced it, but photo proof would be helpful to prove any damage.
I have a “10 and had the recall done a few years ago when the parts became available (I’m sure that will be the next issue, no more replacement parts).
The local dealer did a crappy job in my opinion. The bottom sil plate on the door needed to be popped into place in multiple locations. When you open the door and can see the side of the dash wasn’t seated in multiple locations either. And now that I think about it; the glove box hinge now hangs up somewhere(some kind of clearance issue at the pivot in the center) and yeah I’m pretty sure they pop off part of thecenter console and and the shifter bezel. I turned off my accessory breaker because I just new...........they fiddled and tried to turn on light bars and air compressors.
I didn’t take pictures, but I didn’t want to waste even more of my time dealing with them.
GREAT, I thought it was going to be a simple glove box removal or something.
They will probably jack up my anytime backup cam or LED light bar switch I have wired up to replace the dash blank spots.
Yeah - it's for real. The explosive chemistry becomes more volatile over time until it expands so quickly that it causes the metal housing parts to fracture where it's supposed to bend away from the airbag. The result is metal shrapnel.
I feel the same way and I’ll do the same, my 2015 TEP has 7500 miles on it.
I don't think the entire dash has to come off. I took apart the interior on my 2016 4Runner TE, including the passenger air bag. It was a but of a pain, but definitely doable. I almost want to hand them the one I have and pick up the new one and do it myself, but you know how stuff like these recalls go.
Shared album - Rob K - Google Photos
mV5jiDhs3dhegHdx5
But the drivers side airbag is not affected? Never hear anything about it. Same airbag make right, just diff size and shape. I drive solo 95% of the time. I have a 2012 SR5 and have heard zippp from my dealer or Toyota regarding a change out.
Air bag recall
I got a notice two days ago to schedule an appointment for my 2015 Trail Edition. These latest posts are helpful. I will be taking photos of the dash and console in case they mess it up. The last time I took it to the dealer was for the "Free Oil Change". They overtightened the skid plate bolts and I had to cut the plate off later so I could do the lift install. I've been doing all my own maintenance ever since then.
Yes, so what about the driver's side airbag?
The driver side airbag is a completely different design... donut vs a tube-style inflator... and does not have the same design flaw. Also, the dealer will not contact you but you will get a mailing from Toyota directly notifying your recall is activated. Or you can check Lookup Safety Recalls & Service Campaigns to see if yours got missed somehow.
For concerns about damage, I guess it depends on your service tech. I had my airbag replaced last year. It took about 3 hours and they also changed the transmission fluid at the same time. When I got it back, the only difference I could see was the new trim panel going up the pillar of the windshield. It was new and clean and the other trim panel was dusty. No issues with reassembly.
AndiGarage
