alignment issues
ok i have a 97 t4r with 3" spacer lift ........... spun out with the runner and decided to rebuild the front end and the reason is when i drive forward the camber goes super positive and when reversing it straightens out ??? wtf replaced everything except UCA bushings could this be the issue???\:toilet:
What island you on? Did you check your camber/caster bolts? You said you haven't touched the uca bushings, you should look into replacing the whole uca and get after market ones. Just installed these not too long ago and took me about 3-4 hours give or take to install myself Light Racing Adjustable Upper Control Arms Toyota 4-Runner 1996-2002
I'm on the big island , I installed new everything in the front end except UCA bushings , I was thinking of investing in aftermarket UCA but wanna make sure that if I change my bushings or arms it'll correct tha problem ?!?
I'm on the same island too, soo yah before you buy anything make sure to check the lca cam bolts, if you still deciding to get some uca's you should jump on this deal http://www.toyota-4runner.org/3rd-gen-t4rs/177014-gauging-interest-uca-group-buy-5.html
yeah installed myself ........ i realized my upper ball joints arent seating properly looks like theyre on the tip of the threads and this seems to be causing the play in the alignment ??
increasedc
