Aluminum Front Integrated Winch Bumper | TWO IN STOCK!
Are you interested in an aluminum front integrated winch bumper?
  • Yes
    Votes: 96 88.1%
  • No
    Votes: 13 11.9%
  • Total voters
    109
Please show or send me a prototype with half bar and winch and or 20 light bar cutout powder coated
I will pay ASAP
Mike
I’m still definitely going with one of these when they are available!
Looks good! Im ready to buy one once its for sale.
Sent from my SM-G973U using Tapatalk
On my Super White, I would just clear the raw aluminum and run it!
definitely interested. any news on the rear bumper?
Wow. Looks awesome. I’m glad that I waited.
They are now live on the site!
4Runner Front Winch Bumper | Blitz | 5th Gen (14+) - Victory 4x4
4Runner Front Winch Bumper | Blitz w/Tube | 5th Gen (14+) - Victory 4x4
The aluminum version with or without tube will be the exact same design as the steel version, the bull bar will look the same. The only difference will be in the material (1/4" aluminum with 1" thick shackle tabs as opposed to the 3/4" tabs on steel).
The mounting, recovery points, winch plate, and all three faces are tied together allowing for plenty of strength for winching/recovery.
Use coupon code FIVE for 5% off!
Wish this had been available when I purchased mine.
I'm going to order an aluminum one with the bar and powder coat. What specific lights fit best for this set up?
Speaking of lights
I have a 30” Baja I don’t want to give up, behind the grill. Obviously my Rago mounts will not work. And even if a bracket was made to work the install video shows the OE bumper being installed first, then your bumper. Yet other slimline type bumpers you can install the OE bumper last, allowing a behind the grill light to be install if there was a bracket solution and easier install.
I suppose it could be mounted on top of your bumper in front of the grill with no bar....? Not as clean and little theft deterrent though.
Speaking of lights
I'll have to look into how those brackets mount, but a mount that works could be installed before both bumpers are installed. The reason our bumper is installed after the OE bumper is to have a clean, factory looking gap. Our bumper will overlap the cut edge some so it is not visible when installed.
There are two holes on the top of the bumper you might be able to make work, but are designed more so for pod lights.
I ended up going with steel. But it came today! Impressed with how its packed. Took a pretty good shot in the side but that just hit the foam. Not a scratch!
Got my Victory 4x4 aluminum blitz bumper and Warn winch installed!
