Aluminum Radiator and Trans Cooler
jimmyrecluse
Definitely think it's time to bypass the ATF in the coolant issue before it happens, also supercharging
I'm aware that I can install the trans cooler with the stock radiator but is there any benefit to installing a 2 or 3 pass all aluminum radiator along with the cooler? One would think cooling would improve, def would be more durable than plastic. will there be room for a trans cooler with a 2 or 3 pass?
Tl;dr on the video he’s disappointed with the overall quality of the connectors but got it to fit. [MENTION=168172]sleepydad[/MENTION] how’d it perform?
fitment is always an issue with aftermarket stuff. overall I'm 100% satisfied with the cooling performance. With both the OEM fan clutch and electric setup I ran an all summer with AC.
the only change I would make next time... I would get a radiator without the integrated Trans cooler since I run one now with a thermostatic bypass valve.
overall its a great setup and it's been working perfect. was a bunch of fooling around getting it all setup.
tran cooler setup here
charlesz
