Am I missing anything from this order? (lift stuff)
FiReBReTHa
...Or should I order different components?
I figured I should consult the mischief of the group and see what thoughts everyone had :)
Thanks in advance!!!
can't tell if it's included in your cart, but i believe you will need top plate spacers for the 884's to achieve the 3" lift setting, if that's what you are going for. some one correct me if I'm wrong...
also, somewhat general question but applies to you, do most install the sway bar relocation brackets when going +2.5"?
Top plate spacer to fix driver side lean??? I don't remember if it's even that important, uca's!!! You'll want them eventually
oof, forgot about the sway bar relocators, may have to order that from another seller since im not finding it on their site.
Good call out!!
Yea UCA's will be a bit because of cost, but on the list of mischief due to such high recommendations.
Good call out!!
Get in contact with [MENTION=120150]TotalAutomotiveLV[/MENTION] they will get that for you.
Don't forget JBA...
quality UCA: Camburg, ICON, Total Chaos...
I am very pleased with mine. Align great, and very good price point! :becky:
NZDZRT
Hello guys,
i am also in same boat to purchase similar set up for my 16 Trail,i am looking to keep 2.5 in front and 2 in rear,so do i need to ask seller to set them at those height levels or installer will do that? sorry ,i am very new to this.
Sravan
Hello guys,
Sravan
In the rear, the height will be accomplished by the spring. In the front, either set the clip to the height you want, or ask your installer to set the height to 2.5" which will be shown on the included directions.
If anyone has any questions or is looking for suspension setup recommendations please give us a call at 702.979.1577.
Thank you so much for your response. :) hope i dont need UCA as i will be under 3 inches.
Sravan
goddesszilla
