Another Bilstein 5100 question
Hey [MENTION=51725]mybabydaddy[/MENTION] I noticed that you have Spidertrax 1.25" Wheel Spacers with the 265/70/17. Do you rub in any way in full lock going forward or reverse? How do you like your 1.75 front with 1 inch rear spacers lift? Does it have a good factory ride still? Also, did you install a differential drop? Sorry for all the questions, but I'm getting ready to pull the trigger on this same set up. Thanks
Yep. 1.75 front with 1 inch rear spacers gives it a nice stance (lessens the factory rake), but doesn't really affect DD (that I've noticed anyhow).
No rub forward; slight rub at full lock in reverse. Still haven’t trimmed anything tho.... It’s a pretty easy work around if you remember it’s going to happen. For me, the 1.75 front/1 inch rear is perfect for STOCK SIZED TIRES... I wanted to stay with stock size for now. If I were going to mount up 285s, then I’d do the highest setting up front with 1.5 in the back. My truck looks just a hint better than stock, and that’s how I wanted it. Got rid of a little of the factory rake; and much nicer stance (with the Spidertrax). No diff drop on my setup.
EDIT: The ride is definitely different on 5100s at all corners and the spacers in the rear. Some of it is good/better; some of it is a bit annoying. Overall, I’ll take the improvements over the annoyances. Improvements - stiffer/sportier ride, WAY LESS nose dive under braking... just overall a good, firm ride. Annoyances - over rough roads, can get a little “choppy” so to speak... Here in DFW, we have a ton of construction and potholes, so it can get old. But I’d still take it over stock suspension any day.
2.5" and 1.5" is the way to go
I have the 2.5" setting with Daystar 1.5" in the rear and love the way it looks and drives
Yesterday I had my Bilstein 5100's installed. I went with the 2.5" setting up front and added a Daystar 1.5" spacer in the rear. Ditched the stock Dunflop tires for 275/70R17 KO2's.
MAJOR improvement in looks and ride quality!! No more major nose dive during breaking and it soaks up bumps better. Absolutely zero rub and I get to leave the mud flaps on!
I was worried about it looking "goofy" with that amount of lift on 275's, but I actually love the look!!
Does your Trail have KDSS? I am thinking of doing the same exact lift to my 2015 Trial.
1.75 and stock rear with bilstein shocks
I will be adding a 10mm spacer by OME in the rear here soon.
What is the daystar 1.5 spacer part# you used?
1.5 or 1 in spacers
Thanks again for all of the help. I'm still deciding if I want 1 in cornfed rear spacers or 1.5 daystar spacers. What's everyone's opinion about which one I should go with?
I was able to get the Daystar for 28.75 on ebay open box(never installed). I haven't gotten to the actual install yet as I am trying to decide if I want to deviate from stock wheels, so I can not speak to the ride. However, from everything I have seen here, the Daystar and Cornfed products are great! Not sure you will go wrong either way. One may be a little truer to 1.5", but other than that, I'm not sure you'd see/feel a difference.
DionicioLives
