Another Bilstein 5100 question
I dont understand Amazon. 5100's and spacers ordered at the same time, spacers are shipping USPS, Front shocks FedEx, and rears UPS....WTH...
Got my 883 front coils + a 10mm top place spacer installed. VERRY happy with the current setup.
[MENTION=134037]singletrackftw[/MENTION] are the spacers a must? Had you put the lift on and realized you would need them? I'm thinking about going with same setup but wasn't sure how necessary the spacers were.
If you don't do the small 10mm spacers up front you will end up with some pretty significant rake, slightly worse than stock rake. The spacers truly help make it a 2.5 front lift and a 2" rear lift and even that still has rake but it looks fine IMO
And you went spacers on all 4?
Also, don't be discouraged to use these spacers. I hate the idea of spacers as a lift because it seems sketchy to me, but these are so small and they go ON TOP of the strut mount so they won't have a single negative performance effect on how your truck rides or handles off road. I'm not a fan of "spacer lifts" but I'm really digging this setup because it's not a "spacer lift". It's a true coil lift and it works so well.
For the guyd that had shops install their 5100/spacers, what did you pay? I just stopped by a Toy. dealership and got quoted 700 just for the install/alignment....
Rule #1 NEVER have a dealership install aftermarket parts. They will charge you out the butt.
My guy in chandler Az @ Desert Car Care does entire coilover installs WITH alignment for $351 OTD. If you only did fronts or rears separately he charges $170 OTD with alignment.
God I love you. I'm in AZ too and was worrying about where to go. Now I know.
But back to the other question, did you use 4 spacers, all 10mm? That's what I'm confused about because that would just make the front and back both 10mm higher. So why even need them?
Lemme explain:
1. Ask for Mike Tibbetts @ Desert Car Care on McQueen & Az ave. he's my guy and he does really great work. Tell him Tyler Rice referred you.
2. Both of the front struts get a 10mm OME polyurethane spacer whereas ONLY the driver REAR gets 1 single 10mm TRIM PACKER to compensate for the slight drivers rear lean that our 5th gens have. It's a real thing.
Front top strut spacers
Vs.
rear SINGLE sided trim packer (goes on top of coil rather than on top of strut)
I bought all my suspension goodies from Wheelersoffroad.com except for my bilstein struts. They have good prices and amazing CS & knowledge.
Lemme explain:
Awesome. You're the man. Definitely going with this setup or something very close. I'm considering the wheelers t13 coils for the rear. Not that I have any issue with spacers, I don't, but that might give me slightly less lift. Still contemplating that because I will have 275s and don't want any rubbing.
I highly doubt you would have any rubbing with my setup and 275's. Especially if your wheels are less aggressive than mine -10 offset
How do you think the 1.5 in the rear would work out with no spacers in the front but only 1 in the rear on passenger side? I don't have KDSS either and I thought that's where the lean comes from. How were you able to notice your lean?
The more I read about the lean the more I saw some people with NON KDSS runners also had it. So I took the chance and had the spacer installed and sure enough my rears are perfectly level whenever I measure them. 1.5 in the rear and no spacer up front should be perfect!
2 questions- do hate me if it's been answered
What I have- 1 inch Cornfed spacer on the front of a 2016 SR5 w/20 inch wheels.
What I want- I would like to have the rear set 1 and 1/2 inches higher with the whole vehicle level ( no front rake).
1.How/can I do this using only Billstein 5100 and spacers? (Settings,size of spacers,etc.)
2. Is this recommended?
:confused:
:confused:
I have a 2017 SR5 and I installed Bilstein 5100s all around with the fronts set at 2.5" and 1.5" Daystar spacers in the rear. The frame came out perfectly level with a 1.5" forward body rake.
Before:
After:
Sent from my XT1585 using Tapatalk
Before:
After:
Thank you for the input. I will start my quest to make this happens. If my wife asks.. you guys saw nuthin'. :spy:
Can you guys with the 5100 and spacer in the back comment on the ride after install vs the oem shocks.
This is all a matter of personal preference, I suppose. For me, the ride is vastly improved--much more solid. Gone is the mushiness. Gone is the nose dive on braking. Yet the ride is not harsh. Bumps in the road might be ever so slightly better absorbed.
I did Bilstein 5100 on all 4 corners, set to 1.75 in front, with 1" Cornfed spacers in back. It is also important to note that I have KDSS, but that should really only affect sway.
Before:
After:
Follow up question:
You still have a front rake. Can I use my existing 1 inch Cornfed with a rear 1.5 spacer to level out the "look"?
DionicioLives
