I bought an L-shaped piece of aluminum from the hardware store. I cut it to my desired length and then drilled holes for the maxtrax pins and for bolts to go into the side of the crossbar. It was only a couple of bucks and it’s been working great.
Did Toyota change the bolts used for the stock rack? My stock bolts from my 2018 are much larger in diameter than the bolts that came with my rack.
did you remove the stock bolt and check the bolt that came with the rack? I think the bolt head is just bigger on the stock one, the shank/threads are the same though. IIRC thats how mine was.
Stock bolt is on the bottom, bolt they sent me is on the top. Threads are different too.
Installed my rack yesterday and the bolts fit perfectly i have a 2018 also
Good to know. Did you happen to compare the length of the bolts they sent you to the stock bolts? I'm planning to just re-use mine I think.
