Any damage if I keep everything else stock?
Wow,
You guys have hit on a lot of important topics in this thread! While most of what you guys posted is true and none of you really went out on a ledge you couldn’t get back from, it seems you are combining many questions and attempting to answer them all at one time. After reading through this thread here is what I perceive being asked:
1. If I add extra weight to the front of my vehicle will I need to upgrade the OEM suspension components?
2. If I add this weight in the form of a steel bumper will it make the occupants of the 4Runner safer?
3. How is the steel bumper different than the old bumper as it pertains to “crumple” zones?
Before we begin please take a look at this old guy named Newton and his three laws:
(BTW get a coffee and pastry or a Coke and nabs because this will take some time!)
1. First law: The velocity of a body remains constant unless the body is acted upon by an external force.
2. Second law: The acceleration a of a body is parallel and directly proportional to the net force F and inversely proportional to the mass m, i.e., F = ma.
3. Third law: The mutual forces of action and reaction between two bodies are equal, opposite and collinear.
Alright, got that? These won’t help answer the first question but will help answer the other two. OK, here we go:
Short answer – No. Whodat compared it to a fat kid sitting on the existing front bumper and that is as good as any. What you need to think about is what components will have an additional load by adding 60-80 more (New bumper – Old bumper) pounds to the front of the vehicle: Tires, torsion bar, Upper control arm and front suspension.
Tires – Remember your front tires are rated at a maximum load just like the rear tires and usually they are the same tire. You don’t think twice about putting 400 lbs on your hitch, two adults in the back and all kinds of gear in the cargo area so what are you worried about adding weight to the front? So tires should be no problem. Front suspension components though are a little different. You basically will be preloading them a little more with the new bumper. Will it handle different? Sure, a little but probably not any different than two 250 lb people in the front seats vs two 150 lb people in the front seat. I could calculate the weight delta at the CL of the front wheels of the bumper of adding 80 more lbs of bumper vs adding 200 lbs with the people but my gut tells me it would be close. Add it to the fact that a vehicle’s load changes from one trip to the next (500 lbs in the rear or 400 lbs in the backseat) and you see what I mean. Think of it this way: I add 80 lbs up front. To offset this weight I add “X” weight to the rear and the resultant will be a wash.
Personally I think you will have a little more shock wear over time. If it were me I would put some “C” rated tires on it which will give you more sidewall stiffness. I probably would add a heavier shock too but then again this is what I am going to do with my stock 4Runner anyway to help handling.
Answer = No. What it will do though is minimize front end sheet metal damage in a low speed impact. There are two ways people get hurt in a vehicle during an accident: A) Something that does not belong comes into the passenger compartment like a steering shaft, engine block, sheet metal, rock, etc. or B) Sudden acceleration or deceleration of the occupants. Item “A” is easy to explain. If you want to know more about item “B”, then Google Col. Jon Stapp. He was the “test dummy” that I learned about in Dynamics class 100 years ago or so. Suffice to say a human body can take a lot “G’s”. I will say that while the added bumper will increase rigidity of the structure it will also increase the sudden deceleration on the occupant, which in my mind will negate any gains. A quick word of vehicle safety from my sponsor:
The safest vehicles are modern race cars. If you really want to make a safe vehicle then add a complete roll cage, a HANS device, 5 point harness and helmets. This is what is required. Anything less you might as well keep it stock. Remember all the crash test data is at relatively slow speeds. Ever wonder why they don’t test at 70-75 mph? Because you usually don’t walk away from a crash at those speeds in any stock passenger vehicle.
The biggest problem though of adding that bumper is what you could do to a pedestrian. Vehicles are designed the way they are not because all engineers are thoughtful and safety conscious, but because there are rules and laws governing design. Pedestrian strikes are why front ends are designed the way they are. Of course slow speeds only as high speed strikes cannot be made safer. This brings us to:
My answer in a minute. Here are a few examples of crash scenarios. See if you can pick the one most likely to walk away.
• Bicycle hitting a Toyota Prius head on at 70 MPH.
• Prius hitting a Dodge 3500 Mega Cab 4X4 head on at 70 MPH.
• Dodge 3500 Mega Cab 4X4 hitting a Long Nose Kenworth head on at 70 MPH.
• Long Nose Kenworth hitting a Bridge Support head on at 70 MPH.
The answers are easy right? Referring back to Newton’s laws you can see that heavier is better until you get to the bridge support. Nobody wins when you hit one of those.
Never forget that the design of ANYTHING is all about compromise. Designing a vehicle like ours is no different. A consumer wants:
• Great looks
• High performance
• Safety
• Comfort
• Fuel Efficiency
• Reliability
• All at a low cost
Looking at the list above you can see how for example, fuel efficiency could be improved if we got rid of all the added weight of the airbags and safety hardware. Comfort could be improved if we added La-Z-boy recliners. That would make safety and fuel efficiency take a hit though. We could increase performance but reliability and efficiency would suffer. You get my point. It’s all about compromise. NOW to answer question 3:
It is probably easier and cheaper to make crumple zones. Full frames use a lot of steel and add weight, which decreases fuel economy. So, which one is safer? Go back up to the crash scenarios I listed above. Looks like mass is king there. In a low speed crash crumple zones are fine. They deform and protect the vehicle’s occupants. But at least in my mind mass wins at higher speeds. The vehicle engineers are constantly having to make compromises to meet the needs of consumers and to stay within the safety and fuel economy rules set forth by our government. I am a firm believer in safety but I understand compromise. Your steel bumper is no safer hitting a bridge support at 70 mph than anything else as your percentage of mass did not change much. Just remember, if something is designed to crumple, it will crumple even more at higher speeds.
While everything above is based on fact there are opinions in there too. Hope you enjoyed my answers. Good luck and I like the looks of them too!
Thank you, sir. Always like reading your lengthy, detailed, straight to the point posts! Do you ever get tired of being an engineer at work, then coming home and being an engineer on here :) Thanks again for taking the time to post this. I'll post updates later when they come.
My friend put on a ARB front bumper on his new Tacoma with stock suspension for 5 years and 140k miles with the bumper on with no problems. Sure his shocks needed replacement after 100k miles but he off roaded a lot. So if I were you just put on the Shrockworks front bumper and see how it handles, if you are not satisfied upgrade as you wish.
If I were in your shoes and had a wife that yanked on the wheel on emergency situations to avoid accidents prematurely I would of gotten the KDSS model. This would help a lot to reduce body roll in maneuvers like what you described. I would think the non KDSS 4runner would lean more and would freak out your wife in certain emergency situations causing a dangerous situation even more dangerous. So a KDSS model would of benefited your wife in these types of scenarios.
This is the reason if I ever do purchase a 4runner it would be the KDSS model seems to be more stable.
Honestly, I didn't even test drive a TE or Limited because I didn't even know they existed... At the time, I looked for an SUV for around 30K and either they were too small or not reliable IMO (like the ford explorer). I thought, hell, a toyota suv for 31K, hell yeah! I didn't even know 2010 was the redesign year until after i bought it. I was really naive about cars/trucks and such back then. Sad, I know. We just wanted a SUV for extra clearance for snow, we lived in the sticks at the time and our cars got stuck in the snow drifts. I really like the 4R and the SR5 worked and still works out great for us. But I do agree with you, the TE or LE would actually be better for my wife right out of the box. But that was something we didn't want to spend so much on, just signed the papers for our house back then, then a new truck, we didn't want to spend too much money at once lol. Most of her accidents were due to highway driving for school rotations, but now that she's done, all of the highway driving is done with me as the driver. In hindsight, I would still buy a SR5 because it's cheaper than the other models, saving me money to mod it the way I want to. Eventually I would like to go offroading/overlanding with my family. Some of the pictures I see on here and other sites makes me really wanna "get away from it all".
By the way, what's the final decision with you and your wife, CRV, Rav4, 4R?
This is who I am. The. Most. Boring. Person. Ever. Just ask my family haha.
We drove the CRV twice she likes it. But she said we can get a 4runner. But it would have to be a used 2008 or 2009 4th gen as I do not want to spend $40k on a vehicle right now. I just closed on a house last year as well and especially a baby on the way.
She told me we can get the 4runner.. but I think she is saying that to make me happy. But I think I will get her a brand new CRV and later get a used 4runner myself when finances allow me to do so. She is more comfortable driving a smaller vehicle. She drives a big vehicle fine on the road just she is worried about parking a bigger vehicle.
shes definetly saying that just to make you happy.
get her the damn crv and get yourself that 09 later :)
90% of the situations we have with our wives/girlfriends seem to follow the above scenarios
Ok, i've had the bumper for about 2 weeks now and I hate it! I hate the 4Runner in general now! Just kidding, just being a troll ;)
I love my new SW bumper. Even with everything else stock, the bumper makes it look a lot better. Love looking at the 4R every chance I get :) you guys have to keep in mind this is my first after market mod that has ever cost this much. No regrets so far.
I measured the sag 2 days later, and it was only 1/2". I should measure it again because it kinda looks like I have a bigger rake now, but when another SR5 4R drive by me once, the rake looked similar. I'm probably just paranoid.
I can definately feel a change in driving experience, the steering is abit harder, not enough to complain about, just an observation. Oddly enough, the handling seems to be ever so slightly better with the bumper. Crosswinds affect me less now, less, doesn't mean they still don't affect me. Turning a corner still feels like the truck can roll over, but it seems like I could go a little faster till I reach that uncomfortable tire screech telling me to slow down on turns. Nosedives I have yet to try, usually have traffic behind me, don't wanna cause an accident.
here's a pic, no where fancy that the 4R couldn't handle
2012-03-18181917.jpg~original
Next on my list are tires with better sidewalls (debating on which tires now, I keep going back and forth), or Bud beefy bump out sliders (overkill? Yes and no. not gonna be used for rock crawling, but more for extra protection in the event of a car crash, so it's worth it to me)
I'd imagine you should just be looking at the Michelin line given our inclination towards quality and safety.
They really are the best tires made.
Nice bumper, one day I want to get this too if I can convince my wife that it helps safety : ) how much did it cost you with the installation if you don't mind me asking?
looks good
Michelins are definately one of my options, by the time winter comes back, my treads will be due for new tires for snow driving.
I paid 130 something for the install. They said it would take them 3 to 4 hrs, took them 8hrs. Still charged me only 130 somt. It would definately take me more than 8hrs so money well spent for me. I must say, I feel much safer with this bumper on. Def worth all the cost. I think socal was in an accident in another thread, thankfully no one got hurt, bumper had some powdercoat scratched off, but no dents. Other car's door messed up. Curious if the 4R's frame got bent. Better the frame bent than my passengers hurt tho.
Tflow, right back at ya man ;)
I forgot to mention, my acceleration capabilities also went down due to the extra weight. It's something I expected and nothing alarming, it's not a dramatic change, still able to merge onto the interstate traffic with ease.
I didn't want to start another thread...I finally got new tires!
2012-05-16181941.jpg~original
First off, I was smiling like a little kid on Christmas morning when I finally saw the Duratracs on the 4R :)
Size is 285/70/17
Rubbed on the rear of the front wheel well. Removed the little rubber piece that was protruding out. Also removed front mudflaps, figured the running board was doing a good enough job as the mudflap lol
Only drove 15 miles back from work. As I was making a sharp right turn off a busy street like I always do, I was waiting for the bodyroll...significantly reduced!
I could barely hear the hum, will wait later some other night to listen for it when there's no traffic.
And finally, the screwdriver in my kid's mouth has no head on it, it's one of those with replaceable pieces (phillips, flathead, etc), or maybe he swallowed one :(
So far very happy :)
i'll be the rain on the parade
So, looks great and kick ass build!
But - putting on 285 Duratracs just took away from the "safety" of the vehicle. You justified a lot in the name of safety, and the Duratracs detract from that especially in this size. You could have spec'd stock size Duratracs and not compromised as much.
1. Larger/heavier tires are going to increase your braking distance and compromise your ability to stop.
2. Off-road tread pattern isn't going to be as responsive on the road in emergency maneuvers
3. You stuck a tire that has a rim width recommendation of at least 7.5" on a 7" rim, which causes additional stress on the tire bead.
Don't get me wrong, looks mean and I am sure in the snow with studs it will work great, but for the rest of the time it is being driven, it is a compromise.
Besides, since your wife really liked the ride of the CRV, I have a hard time imagining that she will remain happy in this rig as the tires wear in and get louder (they will, give it 10k) and provide more road feedback. If she does, more power to you, but if you need to unload all those goodies, just shoot me a PM...;)
Updating thread and just saw these replies...sorry
We need some more pics from farther away. 4Runner looks great!!
20120926_133919.jpg~original
You make very good points and I agree with you. At the time, my wife was driving the 4R and I was going to start driving it when we get her a new vehicle. I was eye balling the 285 Duratracs for a long time :) I am a significantly safer driver than her and the safety issues stated above would not be a concern for me, knock on wood. I am a very cautious driver, I don't like it when people talk to me when I'm driving, it's very distracting. My wife would ask me "you don't notice "blah blah blah" when you drive by it everyday?" It's because I just focus on driving and not really care what I drive by.
I'm just at 5k now, and the noise is not there "yet". She doesn't mind noises, just as long as they're not noises from the vehicle falling apart. And my wife actually prefers the truck-like ride over soft rides from luxury vehicles. I think you're mixing me up with Chmura :)
It's been about 9 months since I had the SW bumper and about a month or two ago at full lock, turning left, and going reverse, I had some rubbing from the metal piece that covers the washer fluid reservoir
20121211_101403.jpg~original
The picture doesn't show it rubbing, but it does at full lock.
That was to be expected over time. I don't think anyone mentioned this before because almost everyone usually upgrades at the very least their suspension when they got the SW bumper, mine's still stock. Currently, we just don't fully turn the steering wheel lol I'll keep you guys updated as time goes by, will eventually get bilsteins, at the minimum :)
And this is how she looks currently
SC20121015-134851.png~original
matisgugle
