Any major problems with your 4 runner...
77k on my ‘16 trail! No serious issues yet! Actually, I was thinking about this the other day: this is the longest and most miles I’ve ever driven a vehicle!
This is the only reason I keep going back and forth on an extended warranty.
How much is an extended warranty? Most say they are a waste of money but I know some folks that have saved big $$$ with them, none of them had a toyota.
'15 TEP +KDSS. I've used it hard - but not abused. At 48k miles. The stock battery was getting weak so I replaced it. Seemed a bit early to replace under 4 years old. I do use it probably a little harder than some when I have a fridge along and/or using the winch. Otherwise - no issues with anything OEM.
I've had my share of offroad minor damage. Broken skid plates, bent rear lower control control arms, - stuff like that. Nothing major and nothing that would have ever been an issue in normal use.
Yes, mine keeps whispering in my ear to modify it... It is a major problem... for my wallet.
This is really the biggest downside. If only there was a away to turn that feature off..... Cost me a bloody fortune so far, my wife calls my rig "my girlfriend"
You can see my details in my signature. 80,000 miles. As far as actual issues go I have had ongoing issues with the HVAC blower motor. Replaced 3 times so far. Other than that no issues I didn't cause in one way or another
I have a 2010 Trail with KDSS that's about to hit 110k miles. Bought it with 85k and I haven't had any problems with it in two years of ownership.
Only one major issue,my wallet is becoming lighter and lighter due to the mods I am planning to install and I also want to trade it in for a TRD Pro.
'10 SR5
Front driver side wheel bearing replaced @ 114K, passenger side @ 128K (replaced yesterday).
ECGS bushing installed on the front diff @ 75K because I was getting the drone.
XM antenna went dead but I'm not paying the $350 the dealer wants to replace it.
'12 SR5 purchased at 37K used.
@ 56K I took it in to the dealer for a bump sensation when you released the break at a stop light.
Turned out it was a warped main drive shaft. Toyota replaced it under warranty due to a TSB recall notice. I point the "grease gun of blame" at the previous owner for my premature failure.
Currently at 95K and I make sure to grease all 6 zerk drive line fittings at each oil change!
Rear Hatch Dust
Any of you experience any kind of major failure with your 4 runner that was not contributed to abuse?
Dust has disabled my rear window, stopping it from rolling down twice in two years. My rear hatch lights are full of dirt, so even though I put in LED bulbs, they're still dull brown. Both lights go out intermittently, until I open them up and vacuum. Rear hatch pistons are moving really slowly now, too. Dealer fixed it twice, told me they won't cover it a third time.
Just under 99,000 on my 2010 SR5P. FLAWLESS. I tow, I off-road regularly, and I use it as a truck.
Not. One. Issue.
This is the best damn car I’ve owned. Hoping to get half a million miles out of it. We’ll see if the Midwest winters and salt agree with my plan. Just maintain them as recommended.
I bought my 4Runner used with 75k miles on it last July and it now has 97k miles, no issues whatsoever outside of maintenance and wear items and equipment upgrades.
AndiGarage
