Any TPMS Display's?
I wonder that too. Anyone tried that or have a tpms head unit installed?
What aftermarket tpms units has everyone used? I'm seeing lots of units on ebay
its easy to do if you have the techstream software, i use that with a vxdiag plug.
to get a sensor reading, on the software, you need to go in the vehicle info and read the status.
then one by one, let the air out on the tire, that way will tell you which one is dead. make sure to copy the numbers on notepad, and label them.
amazon Denso 550-0103 for like less than 40.
the hardest thing to do is break the bead. use your truck or other vehicle as weight when using the bottle jack to break the bead. took me an hour to do on the camry. or you can pay tire shops 400 to replace all 4.
I hear ya , when I changed my sensors to TE wheels the guys said the gaskets & kit for them were all I had to worry about . And scrap junkyard forgot they have to be programmed . If I had to do it over would just shut it down , always used to check my pressure myself , nice tech though !
don't know if the system is stand alone, or influences ABS/braking response. i don't like them either. their batteries last 5-10 years, and of course you need to dismount/remount the tires to replace, plus program. mine are original in my '07. the light has constantly been on (plus vac, etc; could be unrelated). i see OE for sale on ebay for $30+/-. gonna pick up five and replace with my soon tire change-over. hopefully all dash lights go out as well.
erinobr2000
