blackoutt
Calling all long tube or catless header owners with functioning URD o2 simulator for the 4.7 V8. I have Doug Thorley shorty headers with no cats and was getting p0420/0430 catalyst inefficiency faults so I installed the universal URD o2 simulator (no plug and play for our engine) now I get p0606 ecm error which from research is pretty commonly driven from erratic or unexpected o2 sensor signals. If I install the bypass plug for the simulator no p0606 will log but of course 420/430 come back. Power and ground check out good. I wired the tan reference wire to common "brown" wire from wiring diagram on the o2 sensor pin 4, confirmed by Gadget that they are 0v reference and wired correctly. Do I have a bad sensors? But why only with simulator plugged in?
Further driving today revealed I can get p0138 and p0158 to show up in pending faults, which are bank 1 sensor 2 and bank 2 sensor 2 voltage high. It is possible that I have the gains set too high? They are at 90 gain and 65 filter as recommended in the installation instructions. Any one elses confirmed working adjustments would be greatly appreciated.
I've ordered 2 Denso rear o2 sensors as well.
I plan to monitor sensor output voltage, I didn't see anything in Torque lite app that would show data but assume I can do so in Techstream?
