Any way to disable this?
chetJ
Is there a way to disable the speed based functioning of the NAV unit in the 2011 Limited? I am referring to how gimpy the Nav becomes when you try to operate it past 5 mph. Could it be as simple as just cutting that freakin wire?
Any response / advice appreciated!
C
There is a plug in module for a couple hundred dollars, and I believe some threads on home made remedies.
All available here on prior threads.
I definitely remember seeing something about the plug in module but am having a hard time coming up with search terms to bring those results up. Every time the stuff that comes up is speed sensitive volume control disabling!
Check out [MENTION=15785]J.A.[/MENTION] and his website. He has detailed information on his site. [MENTION=74569]SOcalTRAIL[/MENTION] I believe did a small writeup or pictorial on that as well.
Do the 2011's come with entune? I am not sure if their bypass trick is the same with the entune systems.
Edit:
Found some info.
http://www.toyota-4runner.org/5th-gen-t4rs/121151-nav-wire-mod-hack.html
http://www.toyota-4runner.org/5th-g...edition-beast-build-thread-2.html#post1129780
http://www.top4runners.com/ja/2007/navoverride.html
Thank you so much for the info guys! [MENTION=76524]vas2101[/MENTION]- did you install the unit yourself? Was it a difficult install?
Hi Jason my 2011 LE did not come with the Entune, so the info you shared should work. I will keep you posted!
Yes I installed myself. It vas not difficult at all. It came with wiring instructions, and how to remove head unit I found here on a forum.
upanatāt
