Anybody running 295/75/16s?
DeTwizzle
If so, can I see pics!
I'm running 255/85/16, and my next tire needs to be a little fatter, these 255s are kinda like pizza cutters.
I think this is probably the biggest tire size I can run without a BL.
http://www.toyota-4runner.org/3rd-gen-t4rs/78227-4runit-build-thread.html he is, but its not a 16" wheel he is using a 17", and he still has rub with his lift and spacers, i was just talking with him yesterday about his tires, cause ill be getting them by this summer. you will need wheel spacers to clear the UCAs and then you will have some pretty good body rub so you will want a BL. i personally would just get the 285s they are gonna be noticeably wider than your 255s
Yeah, I'm up it the air on which way to go... but the last thing I want to do is go down in tire size, even a percentage. Rather go up a percentage, crank on the coils a little more, and grind away. And the 295's are significantly wider than a 285 too. I'm not too worried about it rubbing on my UCA, my rims have negative 4.5inches of offset and I'm running the Camburg UCAs, which are a little more pulled in I believe than the stocks.
I really won't need new tire till the beginning of next year... but if the Mayans are right, I might not need tires ever again. :beer:
