Lift is in and wheels/tires will be installed Monday (Fuel Throttle 17x9 and 285/70 Nitto Terra).
As far as the lift goes, here is the run down:
I installed 884 springs on the front and 895E on the rear, with Bilstein shocks all around. Wheelers just could not get them in...
Ride is a little stiffer then stock, with less nose drive on braking. It actually feels pretty good.
Stock height was 34.5" front and 36" rear (ground to fender edge).
Now 38" front and 38.5" rear drivers side, passenger side sits a touch higher.
My alignment numbers weren't to bad, seeing I did not do UCA.
Camber is 0.1 both sides, caster is 1.9 / 2.0 (wanted more just not any adjustment left) and toe is .03 / .04 (total toe .07). Steering feels better then stock, so who knows what the numbers were from the factory!
I am sure UCA's would bring the caster numbers into (or better) spec but this will not cause any "strange" tire wear, just maybe not track as well as it could, but to be honest, it feels better then when I drove it off the lot. pics of how it looks now are in my album.
Stay tuned for Monday evening pics and posts!!!
