Anyone have Nitto Trail Grapplers
cgill00
I have just installed a 3" toytec ultimate package on my truck and am looking for some new tires. If anyone is running 295/70/17 nitto tires please give me some info if you are experiencing any rubbing
Thanks C
I get a mild rub in reverse at full lock with the 285/70/17's. Im at stock height though, and its just on the fender liner.
Thanks C
where'd u get the install done?
I got It put in from north shore offloading, i really can't decide on what size tires to get...
didnt know nsor was able to work on rigs with kdss. how much did they charge?
in terms of tire size 285 would be my choice. have u tried asking nsor or other tire specialists for recommendations?
u planning to off road that rig alot?
40% off road i also have a gsx 600, i am really wanting to get the nitto trail grpplers but I m not sure if they will rub 295/70/17
you might need to do some trimming but it'd probably fit. not 100% sure, ask the guys at NSOR.
I have a 3" and 2" lift on my trail with these exact tires. I have molded the lumps back in the two mudflaps and moved the front inner fender splashguard up about 1/2". I only get minor rubbing on the back when reversing down a slight to steep incline. No rub when reversing on flat land.
I also have 1/2 - 1" more offset with my rims.
Do you have the terra grapplers or the trail grapplers? Cause the trails are a whole lot meatier then the terras.
Consider re-gearing also if you go with a LT295/70R17 Trail Grappler since it is heavier then most MT's and also it's a taller tire. You still can run the tire without re-gearing but you will lose a little power and gas mileage.
