anyone paint their FJ 17" rims ?
drtyjerz47
hey guys i have a IJM 99 4runner with FJ rims on it. I'm wondering if any one ele has painted them, what they look like now and what they used. I'm thinking about doing mine but I'm not sure on how the finished project will come out
I just painted a set of my five stars this weekend.
Duplicolor wheels graphite grey with light coat of clear on top.
Duplicolor Coats (sold on Amazon)
2x primer
2-3x graphite wheel paint
1x light coat wheel clear coat
Results .....
* 1st one is indoors, other 2 outdoors.
The prep is car soap and water wash wish a sponge, the rinse, then scrub with soap and a purple 3M pad soft/medium grit. Then rise.
Then dry in sun and with clean cloth. Then quickly wipe with paint thinner .
When all that is done time for primer.
Two coats ten mins apart.
Then Let primer settle for 30 mins then begin coats.
For paint coats allow 10 mins between coats. 2-3 coats. I'd let the final paint coat sit for 20 mins then do final coat of clear. Only one coat of clear is all I did.
These were pretty much the duplicolor instructions.
I did two wheels last weekend, two next weekend. I wouldn't try to do all 4 at once. Its a lot of work just to do two properly. Better to do two the right way than a quick job on four.
The paint will dry to the touch in 2 hours but it takes 5 days to fully cure. That means if you mess up (say a run) and need to sand and repaint - you have to wait 5 days. That is the instructions.j
so no sand paper at all was even used. i see.... i have some nasty pits/nicks/chips in my wheels which I've been sanding down 1 wheel for a total of 2 hours now with more sanding to go... and thats only 1 wheel!!!!!!
if you did use sandpaper what grit would you use>? looks like ill have to go finer because of the swirls from the 200 grit
... did you use etching primer?
I did use sandpaper only on the major scratches . First 80, then 180. Also consider a wet sand with the 180.
Definitely no need to sandpaper the whole wheel. The 3M purple pad will to find for the other parts.
Those wheels were previously powder coated so I only scuffed up the surface paint and didn't strip to the metal.
