Anyone running 255/75r17?
oldmansimek
About to install a burtman 2/1 kit on my girlfriends 06 and am trying to figure out what size tire to run. I am looking at the good year duratrac 255/75r17 which is 32x10 is anyone running this size tire?
I used to run it, great stock upgrade size imo. You will need that spacer lift to make it work. You can check the pics out on my build link
I ran that size for almost 2 years before bumping up to 255/80/17. Might rub the front bumper some and I had to push the bumper liner forward.
Currently running it and love it. You may have some rubbing issues with that small of a lift though, but it is possible you wont.
Always take the advice here with a grain of salt. I have a 3 inch lift and after market UCA's and people here told me I would still have rubbing issues. That was not true at all.
All I had at the time was 3/2 spacer lift.. stock everything else. I pushed the fender liner forward so it wouldnt rub offroading.. otherwise it was fine
I run that on the stock rims, stock suspension, got the Rear air suspension and XREAS
Running the jeep takeoffs (Wrangler SRA?)
Minimal rubbing unless full lock and on uneven terrain. Rarely in normal driving.
That is a good tire size- a true 32" tire and doesn't look or handle too narrow. That size drives great in the rain and snow, too. I've also used 235/80r17s and those were a little too skinny. Lots of great options in the 255/75 and you can usually find take-off tires from Wrangler Rubicons.
I have over 45k miles on that tire size 255/75/17. Just bought my 2nd set of tires in that same size. I think it is perfect for what I use the 4Runner for, the only lift I have is the spring hat spacers.
Bill
I'm running 255/80/17.
I love them. Perhaps look into the 80 as opposed to the 75
I don't want to go over 32" on the tire and for all intensive purposes I think the skinnier tire will help on the road with snow rain etc. I like the duratracs I know they are a little aggressive but I really like them on my plow truck. Really appreciate the feedback hope to get the lift on this week and get alignment before ordering tires.
FWIW, the Duratracs are great tires, but they are not as well suited for releasing accumulated mud/snow...I went with the Cooper ST MAX versions (255/80/17) and I must say they seem to be a better tire for these parameters...though I must state, if your GF is more of "mall-cruiser" than an avid off-roading enthusiast, perhaps the 10ply coopers should not be considered as they do offer a more rigid ride...however, if you're wanting a still very well-mannered on-road and off-road tire, you can't go wrong...I personally like the warranty Cooper offers too...just my two cents...
Here's how she looks:
Sent from my SM-G935V using Tapatalk
One thing to note,
I also have the sport model, which has rims with a different offset. I have a 2.5 lift in the front and 1.5 in the back. 265/70/17 are less than a half inch from hitting the knuckle. I can barely fit a finger between them. I'd be surprised if you could fit a larger tire without a different rim or spacers.
I just put one LT245/75 r17 Duratracs on my 4runner. I ran a few trails but nothing too really test them yet. The speedo is pretty accurate. It is less than 1mph slow @65hph. No real drop in power. Stable on the road. I am using 5th gen wheels because they are cheap and fix the offset to closely match the factory scrub radius.
I might go 255/80 r17 next time, but I think want to regear then.
Hp1mdnzThsfgTBZvm0kTn2RhsPJmI97FHmBWXOsybnGEm4CsqgGW9URPuyKyuGFQRpQhH7tl4zBLvSG7zjxoF26vZayzdJKMRwuXpW-7-TBBS7w0xtDcvfKJF-PM2cwWxoTc7Ztbor9edVkP-uqGQPziZO-ndIEHJDVZVXFVNzfJosSR9euMC6b29trWmZugSrJ03gyvT60UHtwErDKYRbyzhZDxKHhNdjMa2nunYbQNj-p1iio9KHBqZxNBvlLHko9AyOyXVWKNO7Z0oVags55WclRHff8dTgi8AdBfBkSdrXM58jDqASct-E3nuUJLAx1VVZz3B_q5-CgOohbxCJuBIm0O8KmA6AFpJZLjv7dxC7u1P3cgoDpZPlboTmmYxdrVylRFyJyjqYWdHqgPNj5XWbbVNSDVhYWTSav2rWvqhxhBVJP284khrKr55aM_UDHPm0MNkZ1_WEREo4SY1d9ELW137LtBh3I_RG3mNa_FkOyETh3cXEiop7lh0qr8OVASWXyxR05p60miNg1MJWRfZdHhQ6D7YN7lRCdVIuIPji9vO0xxdtzw5fqRXNjTYzuXvQ7hvUNSCHvACR9tnkqkHxAst1SNQQLw2GNmKfIRcVpt2MM_GAoQXZ6FRvNAzl8WbwSi0_DZPhXACe5QATu1rIVbIIP5jLQ=w1319-h989-no
Here are my 255/75s in action. I love this size, no complaints at all. Highly recommend.
