Anyone running 315/75r16 BFG KM2's?
Baja Runner
Member
Any pics please ?
I bought some 285/75/16 KM2s and they are tiny. I was assuming I'd get a bit of height out of them over my KOs. I had done some research which I found the 315s ran small but didn't see anything mentioning the 285s. Sure enough they do.
I talked with discount tire and they will exchange the tires no problem. I didn't want to run a 35 because I didn't want to crawl down that rabbit hole. However if the 315s are only a small step bigger then I'd be foe sure ordering some.
Ill post pics later of my rig with them
all the km2's seem to run small. my friend has the 315's on his 4runner and they are smaller than the mtr's
lets keep in mind that the wrangler mt/r's are one of the few offroad tires out there that run true to there size. The KM2's are a lot cheaper than MT/r's though.
Frank, is that the "listed" size or actual size? Ill do some more interwebz searching to see if the 255's actually run at a full 33.
I was just hoping someone would have some photos of how big they actually are. I talked to my buddy at discount to see if they can order some and just do a fit check.
Weird you say that. My Mtr's were at least $30 per tire cheaper than the 315 Km2's. I bought from discounttiredirect.com I haven't looked at tires in while but when i purchased them the 315 km2's were right at $315 a tire.
I just searched and the Km2's seem to have come down some. Either way after owning a set i wouldn't run them again
Thanks for posting that Troy. Still look to be quite a bit bigger than the 285s!! Do you know what size they are when measured on the truck ?
Here is a pic of my 285s. To me they look tiny for a 285 ...
315/75/16's, if Im not mistaken the tires had a decent bit of wear when Weston took this picture.
100_0405.jpg~original
100_0406.jpg~original
The listed size is 33.3. If you search expeditionportal.com a ton of guys run this tire or the toyo mt in the same size and a ton of comparisons between the two. I believe the toyo mt is taller at 33.5. They've got a few pictures comparing it to a 285 and it's noticeably taller. Search "Prospectator" on this site. He has those tires.
http://www.toyota-4runner.org/3rd-gen-t4rs/67552-samster0077s-97-4runner-build.html
http://www.toyota-4runner.org/sale-suspension-wheels-tires/96121-255-85r16-bfg-km2.html
http://www.toyota-4runner.org/new-members/103053-newbie-san-diego.html
all 4runners with 255/85's
Mike Sargent
