anything wrong with putting 10 ply tire on your 4runner?
Sashamil
I just got Nitto Terra Grap. put on my 4Runner. As i was getting a deal i ended up with 10 ply tire vs 4 ply which i originally wanted.
10 ply will just be little havier and harder(stiffer) tire producing stiffer ride or other things will be affected?
Thanks for responding!!!!
Thats correct. It'll be a little stiffer and heavier. It's really just over-kill. They should take up to 80 psi which would normally mean that you can load the $%^$ out of your 4runner but your rim should only be able to handle 65 psi max anyway.
Price is a bit higher too and the ride is a bit stiffer over the hard riding 8 ply Nittos and the stiffer ones are more designed with 5000+lb trucks ion mind not a 4000lb 4Runner.
they should soften up a bit from when you first put them on and just a little fyi we only run 8 ply on are equipment hauling trailers
