ARB 2895e + toyotech/eibach coils
vinceguy23
Hey folks---I just ordered the toyotech "1.6" lift" front and the OME 2895e "2ish lift" rear coils which i'll be pairing with the Bilstein 5100's. I've noticed from this site that the actual lift these coils provide may vary SO I'm looking for advice regarding the proper setting on the front strut (0 or .85) in order to get a level or mild rake on my rig. My obvious guess would be the .85 setting which would yield a total 2.45" front and 2ish on the rear. I don't have any other mods(bumpers). I'm doing the work myself so I'd like to get it right the first time. Thank you for your input.
I would put it at the .85 setting with those springs.
You may also want to consider putting that little 1/4" toytec topout spacer on the driver front while you are at it. If you dont, I can pretty much guarantee that the driver front will be 1/2" low.
Maybe consider the 10mm yellow OME trim spacer on the rear driver too.
Thank you. What is the cause of the 1/2" difference?
