Are the front and rear brake bleeder screws different?
repo
Toyota has different part numbers for fronts and rears and so does Dorman, but the size is the same?? M10 x 1.0 x 35mm. Speedbleed.com has the same part num for both.
And does anyone know if a mityvac vacuum pump will work with the speedbleeders, is it powerful enough to overcome the check valve with a vacuum?
I bought Russell Speedbleeders not long ago for my 96 and I have Tundra brakes up front. They called for the same size on both. But I found that the rears were 10mm and the front 13WL caliper is a 7mm.
Cant find confirmation on the factory 3rd gen front caliper....
I had to use the Russels on the rear brakes and Dorman's on the Front.
No idea bout the mityvac
this. Should have been clearer my first go around. I as well have Tundra brakes up front. Did the same thing and bought the same sized bleeeders for the front and back, but realized that in fact, the rears are 10mm and the 13WL was 7mm.
About to do the TBU on my '01, 13WL up front, can you link me to the right speed bleeders? I see varying lengths.
wayblom
