Attn: Scanguage II Owners!
Dumb question, but do all 5th Gen 4Runners have TPMS? How do you know one way or the other, if there isn't a dash display?
JA
yes, TPMS is required now
[MENTION=178113]ScanGauge[/MENTION] does this actually require a firmware update or can we just enter an x-gauge command? I'm a huge ScanGauge fan and mine has moved from vehicle to vehicle, if this is just entering an x-gauge command I'm competent to do that on my own without mailing it in.
That's pretty neat!
[MENTION=178113]ScanGauge[/MENTION] is there a Canadian address where we can get this done north of the border? I've worked with the guys at Gifford's Automotive in Ottawa before but I'm wondering if this is more of a beta thing they don't have access to.
I was going to ask the same question... would be great if it requires just x-gauge command!
It does require an update unfortunately. There are some extra functions that were added to the XGauge feature to get the TPMS data workin. It's still in testing, but we're happy to update anyone's unit to this test firmware for free.
That's pretty neat!
Since it's still in its testing phase the update is only available directly from our office in the US. However once it's released Gifford would certainly be where you could get the latest firmware.
Put mine in the mail today. You should have it early next week. Very excited to test. Thank you ScanGuage and OP for making this pilot available to the rest of us.
Scanguage
I just ordered another ScanGuage2 to get this tires function. My previous one was sent in to get horsepower display programmed in. I would probably also like to have that done again if I can. The new one probably doesn't come with a horsepower display function already there out of the box.
Sent mine in last week.
How do we know which wheel is TM1, TM2, etc.?
Will we lose the already programed XGauge settings?
And, what exactly do you mean by experimental firmware? Will we need to again update when its no longer experimental?
I'm not sure if the tire number correlates to a specific tire to be honest. From what I understand with the TPMS programming procedure, any tire pressure sensor can be programmed to any tire number. It's possible there's a specific order that's used when they're programmed at the factory though.
With the update, everything is cleared out as the previous program is overwritten, but if you include a note asking for any particular XGauges or settings to be set before they're being sent back our update team should put them back in for you.
It's experimental in the sense that it's the latest firmware with the extra code needed to access the TPMS data tacked onto it. It's not been fully tested so there's always a possibility (even though it's a pretty small possibility) there could be a bug in there that would need to be fixed. Thus I always prefer to let people know it's experimental in case any bugs are found. Most likely it will work fine and you'll have a unit with essentially the latest firmware which won't require any updates though.
I believe so. The parameter ID supports 5 tires. The vehicle I had to test on was simply reading 0 PSI for tire 5, but that's because it didn't have a spare I assume.
I'll send the XGauge for Tire 5 Pressure to ehcanadian see if it works.
I did a little more research here and it appears the 5th gens do not have TPMS in the spare tires, but the #5 TPMS is in the ECU. Would be good to have for those of use who replace wheels/tires with 5 new ones where all 5 wheels have TPMS and would like to monitor pressure in the spare.
However......our sensors also transmit tire temps (see screenshot below). If you are updating the software for pressure, can temperature also be investigated or added? Just a thought.
Shipped out my ScanGauge II today for update.
