[MENTION=178113]ScanGauge[/MENTION] does this actually require a firmware update or can we just enter an x-gauge command? I'm a huge ScanGauge fan and mine has moved from vehicle to vehicle, if this is just entering an x-gauge command I'm competent to do that on my own without mailing it in.
It does require an update unfortunately. There are some extra functions that were added to the XGauge feature to get the TPMS data workin. It's still in testing, but we're happy to update anyone's unit to this test firmware for free.yes, TPMS is required now
Since it's still in its testing phase the update is only available directly from our office in the US. However once it's released Gifford would certainly be where you could get the latest firmware.That's pretty neat!
[MENTION=178113]ScanGauge[/MENTION] is there a Canadian address where we can get this done north of the border? I've worked with the guys at Gifford's Automotive in Ottawa before but I'm wondering if this is more of a beta thing they don't have access to.
This is great, I will send my scangauge in next week. Any word on turnaround time?
Sent mine in last week.
How do we know which wheel is TM1, TM2, etc.?
Will we lose the already programed XGauge settings?
It's experimental in the sense that it's the latest firmware with the extra code needed to access the TPMS data tacked onto it. It's not been fully tested so there's always a possibility (even though it's a pretty small possibility) there could be a bug in there that would need to be fixed. Thus I always prefer to let people know it's experimental in case any bugs are found. Most likely it will work fine and you'll have a unit with essentially the latest firmware which won't require any updates though.And, what exactly do you mean by experimental firmware? Will we need to again update when its no longer experimental?
I believe so. The parameter ID supports 5 tires. The vehicle I had to test on was simply reading 0 PSI for tire 5, but that's because it didn't have a spare I assume.
I'll send the XGauge for Tire 5 Pressure to ehcanadian see if it works.
