4RunnERD
First off I just wanted to thank everyone for the many threads that have already addressed this mod. However, while researching I didn't see any that had detail photos of the installation so I decide to document mine for other people wanting to do this mod. I will do my best to answer any questions that may come up. This is the install of an auto dimming mirror with a compass and the Homelink feature (the temperature is already displayed in the dash so I didn't need a mirror with that feature). I was able to find a mirror with an amber color compass to match the dash lights of the 4th Gens.
To start, I had to remove the OEM mirror. To do this you must first remove the plastic collar around the base of the mirror at the winshield. Many threads said this was an easy step but since I didn't know just where the plastic collar attached to the base and how much force it would take to remove it I wanted to be extra careful. I decided to wedge my grocery store savings card in between the glass and the collar as it was thin enough to fit and it would prevent me from scrathing or damaging the class while gently prying with a screwdriver.
Using the thinest flat head screwdriver or flat blade you have gently pry from the left and right side as the plastic collar only attaches to the mirror base from the sides, not the top or the bottom.
Once you have popped off the plastic collar, slide it out of the way down the neck of the mirror.
Using your finger, pull the plastic tab at the base of mirror towards you. Then gently slide the mirror up towards the roof (not straight back) and off of the metal button that is glued to the winshield.
Continued...
Continued...
