Automatic Running Boards.
Senior Member
Does any one have them? (Automatic Running Boards) looks like a dealer option on Toyota web site. Do those deploy only when door's open or can I override while door is closed for washing the roof.
I have them on my 2012 LE and love them by the way. There is a switch that's says "auto" or "off". You can't make them stay in the out/down position for washing(just checked mine). I had to crack the door slightly and rinse them with low pressure to avoid getting water inside. I guess you could open the doors then find and pull the fuse to keep them out but that seems like to much trouble IMO.
What I find most amazing...is a member with 8 posts is able to provide the answer to member with over 1300...:nerd:
Thanks and no prob. I'll get my post count up one of these days(4R is 5 days old). Maybe someone will come up with a "mod" to wash the boards. Hmmmm
You can have the boards stay out i've done it on my LE...there's a safety feature that does not let your board actuate if pressure is sensed on the board...
Open the door let the board out and stand or apply pressure with your foot to the running board and then close the door. The board will begin to actuate inwards (its an uneasing feeling because your natural reaction is to move your foot quickly lol) and then sense the foot pressure and remain in the out position. I've installed this type of running board on a Tundra and the manual calls it a "safety" feature.
Thanks for info on this one. I've 4th gen so I'm clueless about 5th. Post count doesn't mean I'm 4runner junkie, just like to help when I can.
Automatic retractable running boards no longer retracting
Hi all,
First post to TR4 so please go easy on me. I have a 2012 Limited 4runner with the retracting running boards. About 4 months ago the passenger side board stopped retracting when the door was closed. I brought it to Toyota and they checked it out and couldn't figure why it wasn't going in. We figured some kind of faulty sensor was forcing to stay engaged. Then this week the other side started doing the same. They both retract when the car is placed in motion (forwards, backwards), just not as soon as the door is closed like before. One thing to add is that they do attempt to actuate, but then stay down as if something is in the way.
Thanks for any assistance you may have.
Kevin
I've seen some totally gummed up with salt.
They also feel rickety if a big man (such as myself) stomps up and down on them.
Thanks Bubbles!
I'll try to see if there is something causing the hinge to pinch. I think it is more sensor related but not sure. How's Ricky and Julian?
Are the automatic running boards not available in Canada?
They don't seem to be an option on the Toyota Canada website.
don't get this nightmare of an option. just not worth it, will cause more problems than what its worth. wait till it snows and gets below 10,and it locks up.
I bought my truck in December here in MN. They have not locked up in less than 10 degrees or snow.
Occasionally they will not retract if the starter is cranking at the same time, but they try again shortly after.
Kevin,
I have the same year/model car with automatic running boards. My passenger board sometimes ( randomly) refuses to engage( open) when doors on that side open. It's been a while since you asked for help on this issue and I was wondering if you found a solution for your problem? There isn't much info out there on troubleshooting these automatic running boards so any info is helpful....
Lee
Hi all,
Kevin
