Axle seals - To attempt or not bother... your opinions please
Your interpretation is incorrect. The seal has two lips. The outer dust lip and the inner seal. The polished ring you see is the outer lip riding in the center of the retainer. The actual seal lip is polishing your bevel on the retainer. That is why its leaking. If you want to get a few thousand miles from the repair, put a new seal in and replace the retainer with bevel outboard and moved inboard by 1mm from where it is now. That should get your seals to seal. But to do it right, you should change the bearings. Make careful measurements before you take it apart and put the new parts on. There is very little room for error with these seals.
I did take careful measurements, but we'll eventually know. I'll keep an eye on the ABS area. The other side wasn't oily, at least not yet.
Why would I need bearings?
If the gear lube has reached the bearings, it will accelerate their wear. Short term the bearings will be fine, but they will wear out faster. I wouldnt worry about it right now if they feel tight. Just keep an ear on it for the tell tale moaning of failing wheel bearings.
I replaced inner seals and shoes 10k miles ago + breather - no issues to date with bearings etc...only took a few hours. 198K on the 4runner now.
huh? how do you figure that? why would lubing the bearings make them go bad?
Here's an FYI, for peripheral interest:
When I acquired my 97 4Runner(119K miles) in June, having the wheels off at the tire shop revealed leaking rear axle seals, both sides. Brake shoes soaked on both sides, but no grabbing or other brake performance issues.
PO had receipts for having bought new seals, but may have installed them himself. No biggie--my brother does his own on his big Ram Crew Cab 4WD.
Had the job done at my local dealer: ultra$$...about $1100, but with a one year warranty parts/labor.
Dealer techs reported that the PO had used non-Toyota seals, and had damaged one upon installation.
3 months later, one side leaks again.
Redo.
One week later, the other side leaks agin.
Redo.
They swear(actually, they just said that they "checked") that the axle(s) and/or housing aren't bent.
I'd rather it not leak, and I hope these dealer techs are competent, but for now I'm on the dealer gravy train(or should it be grave train?).
May your axle seal repair be more trouble free than mine!
I'm guessing you haven't read through this. I'm not sure it's a problem on all 3rd gens, but it sounds like it is on yours.
If the bearing is not too lose you can get away with just doing the seal. I did nothing but the shoes and seal at the beginning of summer and have drove a good 10k miles and its still not leaking. I didnt have the case either and doing just he seal cost me $5. Plus it was a learning experience and will be ready to do it right if it fails. Just remember to buy a good tool for removing the seal, dont want to damage that axle housing.
FYI - for what its worth...
98 4runner sr5 w/ 136k
both right & left rear axle inner & outer seals & bearings & tone wheel - $1,400 at independent garage in NNJ
Redo.
Redo.
Your breather is probably clogged and he pressure is blowing out your seals. I replaced one axle seal 3 times before I thought to check the breather. Go for a drive and then open the fill plug, if you have air rush out then it is clogged. Easy fix, pull out the old breather on the top of the pumpkin and replace it with a 1/8th npt barbed fitting and route the hose up into your filler neck. Fail safe and cheap.
Actually, Immediately after the original big dealer seal/brake shoe replacement back in June 2013 I installed an extended breather running up to the gas filler door area.
Used a new breather "valve" that free flows in either direction.
The original OEM breather valve is free flow in the outward direction only, and so typically creates a vacuum in the axle over time and normal heat cycles.
Immediately after the most recent redo of the seals a few weeks ago, I went back and checked my extended breather: perfectly fine, free flow. It hasn't been on the car long enough to get clogged up.
One could logically posit that the seals depend on the presence of the vacuum in the axle housing, but that seems like it'd be extremely shaky engineering.
Both my old Landcruiser FJ 60s and my '91 4WD truck did fine with free flowing rear axle breathers.
Oh, and one last thing: Yesterday, after just a few weeks of boring around-town driving since the last seal replacement, I smelled the telltale smell of gear oil at the left rear wheel. We'll see....
At about 282,000miles, I am considering replacing rear bearings and seals as preventative maintenance. Anyone have more than this many miles on original rear bearings and seals?:guitar3:
