B&M 70264 help needed ASAP.
Yotacollector
I have the new transmission cooler mounted and I want to bypass the stock radiator cooler. Where do the two lines go on the top of the new cooler? Do I connect those to the old lines I took out of the radiator or do I run them all the way back to the transmission? Little confused I must say. Thanks in advance
Just did this last night actually. I left the hard lines that come from the trans and stop under the ac compressor from there I ran two new rubber lines up and out the hole where the accumulator and condenser lines are to the front and int the new cooler
Thank u. That's what I was thinking. Rather then try and disconnect the lines from the transmission, I will just connect to the two "old" lines that were going into the radiator. Thanks!
I used a coupling to create a loop between the two old rubber lines to close the system. The same could be achieved by capping the inlet/outlet on the stock radiator.
Make sure you cap the two fittings at the bottom of the radiator where the original lines were connected. If the cooler wall is compromised, you'll lose all your coolant.
allcarhistory
