Thefishguy77
Subscribed
If I plan to replace my radiator (181,000miles) then I assume it is fine to add the B&M 70268 in series with the radiator cooler?
Yes in series is Highly recommended to control trans temp spikes when in stop/go, towing and/or hill climbing. Ask me how I know! :cowboy:
Was this a problem? Spikes to what temp? I do not tow. I think an electric fan would be my preferred solution.
Thx
Clifford
Well it didn't "overheat" in the sense of causing driveability issues but the temps can reach nearly 240 for the transmission in stop/go and hill climbing (mild central texas hills). I tried using the external cooler alone and later with a fan. It still wasn't enough (temps still rose into 230s) so I went in-series with a new radiator. 240 is just too hot for my taste when the manual says 160-180 is the normal range. I think keeping the high end trans temps under 200 will lead to a much longer fluid and transmission life.
Now the temps won't go above 195 or so for transmission in the same conditions (ambient temps about 100) without the fan. The fan is more useful in slow moving or stop/go but really isn't necessary after going to in-series.
I highly recommend in-series unless you live in Alaska or something like that. Luck. :cowboy:
Thanks BigFish! Awesome write up, great pics and detail. I'll be using this one when I do my tranny cooler!:trophy:
I installed w bypass method and went to the Mojave Preserve for a week. Temp at highest in 1 or 2 long climbs was 197F. Rest of time temps were prob between 145-175. Very happy with it. (seeing 240deg once made me very uneasy and prompted this whole project)
Will keep an eye in summer. I bridged the i/o of the radiator w a length of hose so will be in good shape if I decide to bring it back inline. Tranny, both diffs, transfer, oil all changed before trip- good feeling.
NOTE- I tried the included through-radiator hangars and quickly removed them after seeing the wear they were placing on condenser and radiator. Avoid those and find another method. I used heavy zip-ties to other points and has more space between condenser but peace of mind well worth it.
NOTE 2- When flushing tranny I read hose to driver side would have outflow. Not so in my case- hose to passenger side had the outflow. Luckily I had both aimed at the bucket!
Also got an air/fuel error code so sprung for and installed Denso O2 and a/f mix sensors. I actually feel a difference truck running good.
Thx
Clifford
When you said you did long climbs, how long and steep were they? Was this on road or trail?
No idea on both questions. Paved road like climbing up Cajon Pass or out of Mojave Preserve area to Vegas area. Many miles up grades keeping at highway speeds. Unless there was gear shifting and power the tranny temp was low. As soon as you get some climbing/gear shifting going the temp responds quickly. Very obvious the fluid is transferring friction heat.
C
Next time you're in the mountains climbing a steep twisty sustained mountain road, I think you'll find your temps will go much higher than 197.
In case you don't know this trick, turning off overdrive can drop your trans temps by around 20 degrees under certain conditions. It will help when you're at speeds when around 50-60 mph and the transmission keeps kicking down from 4th(overdrive), to 3rd. Turning off overdrive locks up the torque converter and holds the trans in 3rd.
Interesting info on turning off OD- going to try that for sure! Might help w annoying shifting when using cruise control as well. Thanks!
