Devbot
For a while now I've had this problem with a soft/spongey brake pedal that I could never get firm no matter how many times I bled the system or replaced the fluid
Today I got in my car to drive to work, and clear out of the blue I noticed the pedal was super firm... then I noticed my stopping distance was increased too. I damn near went into the intersection actually
It was firm all the way to my work, but then when I went to drive home at the end of the day, the pedal was now soft again - not only that, but it felt like it was softer than before. Usually I could pump the brakes once to get a decent feeling out of them but that wasn't working any more either
When I got home I went to check the fluid level, and noticed the outside of the cap was now wet with fluid. Pic related
Does it sound like I have a bad booster? Or bad master cylinder perhaps? The only way I can see that fluid exiting out through that little breather at the top is if the reservoir became pressurized somehow, and the only way THAT could happen is if the booster fed air into it. A bad booster would also explain why the pedal suddenly became hard while simultaneously losing braking pressure too, right?
Ideas and opinions are appreciated. Both the booster and master are pretty spendy so I'd rather not throw hundreds of dollars at it in case the problem is something else
