Bad starter at 58k miles??? (2010 Limited)
NYRunner
Member
Soooo, I go to start my truck this afternoon and for a split second it sounded normal, followed by clickclickclickclick until I hit the button again to stop it. Rinse an repeat a few times, same exact thing each time...
Has anyone else had a starter go bad at only 58,000 miles? My truck is stock, no mods that could affect anything related.
Thanks for any input an I hope your weekend is going better than mine! LOL
Dave
Dave
Check battery first and that the connections aren't corroded or loose......that's the sound the starter makes when it doesn't have enough voltage to turn it over.
Thanks for the quick replies gentlemen! I'll go see if cleaning the connections helps and whether my battery pack (jumpstarter) can help get it running.
I'll report back shorty~
Thanks!!!
Ok, as usual you guys were spot on! I have a Duracell 600hd that started her right up! I guess I'll drive around some to hopefully give it some juice, though can anyone recommend the best battery (hopefully from Costco! Lol) to replace the original with? I'm in VT a lot in winter so cold cranking is imperative...
Thanks again for the quick help!!!
[MENTION=8206]harper7[/MENTION] is the man, right!?
Costco (Kirkland) batteries are actually Interstate batteries which are pretty good IMO.
It's all I've run in my boat for 15 years.
Glad it's just the battery. Die Hard Platinum from Sears. It is the same as an odyssey battery but with a different case.
I would stay away from the Optima red tops. I have read and heard A LOT of quality issues with them the last few years.
Between him and you I got to hear it from The Masters themselves!!!
