Baja Rack-Hi Lift
plesley
Does anyone have a hi lift mounted to standard baja rack on their 5th gens?
Im looking for a cheaper mounting option other than the baja rack accessory.
Baja Rack Hi Lift mount
I always prefer the DIY accessories. I don't care for how the lift hangs off the side of the roof rack with the Baja Rack mount. I'd probably make a couple of wood blocks to fit the rack floor to keep it from rattling and then tie it down with 1/4" rope. But the Baja mount is quicker and easier to use and for some reason it's only $70 for the mount to fit the Standard Roof Rack. And who knows, the Baja mount may fit the floor of the roof rack as well as the side rails?
I have a set of these
I have them set up across the back above the shark fin, and just fold them down when I don't have the jack mounted up.
2015-06-05%2016.30.06_zpshaa7ezkg.jpg~original
Yes, but I used their mount. For $75 it was not worth my time to make my own.
Hello and thank you for doing what I want to do.
Do you have photo(s) of jack mounted on the Baja Rack mounts?
Do you (anybody?) use the shovel/axe mounts from Baja Rack?? Photos??
(I searched - really I did - honestly.)
I've decided on full length Baja Rack, mesh floor, sunroof cut out. Want to put jack, axe and shovel back on top and think I want the Baja Rack thingies but sure could use photos before I get them.
Thanks in advance!!!
Yours Truly,
sundog7121 from Durango
BillM777
