BALL JOINTS: Sankei 555 (Moog/Raybestos) Poor Quality/Design Flaw??? My Findings...
nobb
I know there are already a gazillion threads on this topic for our notorious lower ball joints, but I thought I would share my findings and get your thoughts and experiences on this issue. I had the chance recently to inspect some Raybestos lower ball joints. They came in a generic white box with a Raybestos sticker on it, but the actual joints themselves are branded Sankei 555. Many people claim that Sankei is the manufacturer of the OEM joints, and as such, they are good quality. I will argue against this as I've also had the opportunity to compare brand new Toyota OEM joints with the Sankei. As some background info, it appears that these Sankei 555 joints are also resold by Moog, Raybestos, Napa Premium Chassis, and Beck/Arnley.
When I inspected the Sankei 555 joint, I was impressed by the greaseable design and also the fact that the dust cap had a little opening for excess grease to come out. However, that was where my positive impressions ended. The dust boot itself felt thin (like it could puncture easily) in comparison to the NOK japanese branded rubber boot on the OEM joint.
I'm no grease expert, but I'll also comment on the grease differences between the OEM and aftermarket joints. The aftermarket joint has a yellow sticky grease (as pictured) which resembles the generic lithium grease you would get when you buy a grease gun and they give you some free grease. This transparent color suggests to me that this grease does not have much in terms of extreme pressure (moly) additives. The OEM joint uses a white grease which appears to be soap (sodium) based. If it is indeed a soap grease, then it would have excellent water repelling and shock loading properties, as well as being very "sticky" in regards to not being pushed out from contacting surfaces. Once again, I am not a grease expert so don't take my word on this. Just my observations and thoughts.
However, the most troubling finding is the movement of the joint itself. When I moved the ball piece, I noticed a TERRIBLE amount of resistance. Almost as if the ball was grinding inside the socket. It just FEELS like metal on metal contact and in my opinion, this will cause heat buildup and wear. And it is NOT a smooth type of resistance either. It was notchy, uneven resistance. In comparison, the new Toyota OEM joints have a smooth fluid movement.
I was curious as to what causes so much uneven resistance so I took the grease boot off and inspected. What I found was that the ball had a grease channel cut in to allow for grease to be evenly distributed inside the joint. The OEM ball joint does not have this feature. This grease channel could be what is causing the grinding. I cannot say for certain, however.
But what I DID find was very interesting. I will let the following pictures speak for themselves:
Note the scratches/scuff marks on the ball? I literally created those scratches on the fly JUST BY MOVING THE BALL IN THE SOCKET at most maybe 20 times. So if I was able to create those scratches just by moving the ball by hand, imagine what is happening when these joints are installed on a moving vehicle and the suspension is constantly going up and down. I did NOT notice this to be a problem with the Toyota OEM joints.
This can't be normal, so I would like to hear your experiences and opinions of these Sankei 555/Raybestos/Napa/Moog joints. Is this the final nail in the coffin as to why you should only buy OEM? Am I overreacting?
Solution
I am not sure if Sankei is really the manufacturer of the OEM joints because they are completely different than any Sankei branded joint. eg
HERE is what I learned from talking to someone who owns a Toyota repair shop and orders parts.
1) There rarely a sole distributor for ANY Toyota part. Meaning one year Koyo had the contract to manufacture the radiator for the 4Runner. Toyota bought from them. A few years later it was another manufacturer. The SAME thing exists for nearly all parts on a 4Runner.
2) As long as a manufacturer was at one point a direct supplier for Toyota for that exact part (eg Koyo radiator), then you can buy that part directly from the manufacturer with confidence.
3) So given this example say Koyo...
So i have a super nice 167k miles 1999 elocker the body is perfect but has had some rust repair on the frame done by my local frame shop yes it came from rust belt so ok guys were to get oem ball joints at a good price? And what about the upper ball joints ? Im needing rear axle seals and break backing plates , might as well do struts /shocks and all links outter tie rod while im at it, so im hoping i can find a good price on them thanks !!!
1999 Toyota 4Runner Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
Has anyone tried Beck Arnley lower ball joints?
I'm sure some have used them, but let me make an observation...
Of all of the hundreds or thousands of parts in the whole wide world you can get for your 3rd gen 4Runner, the ONE that EVERYBODY AGREES shouldn't be aftermarket is the lower ball joints. Spend the $110 each.
I'm an engineer and failure analyst for a heavy equipment manufacturer and this whole lower ball joint issue really interests me. I have no doubts that there are poorly made products on the market that will fail after a very short period in service, but I also believe there are many other factors at play that end up obscuring the true root cause:
1. Lifted vehicles. Strong possibility that the ball joints with stock geometry were never designed for the stress'/angles that people are placing on them by adding lifts. This is already commonly discussed. I know very little of ball joint design other than their basic assembly and operation, so I won't comment any further to avoid speculating.
2. Installer error. After searching multiple threads, I rarely see any comments about this possibility. Even with qualified technicians, workmanship issues are an everyday concern. Now replace that qualified technician with a DIYer like most of us on here, and that risk explodes. Dont get me wrong, I am in no way criticising the good people on these forums. Whether it is a hobby or a necessitiy, working on your 4Runner is a great thing to learn how to do. (I also do not by any means consider myself to be a qualified technician.) Incorrect installation such as misalignment of guide dowels, improper bolt torque, improper lubricant type or quantity, contamination, and many other factors are real world concerns that will cut a ball joint's life in half or less.
I won't offer any advice or try and steer users any one way or another. When in doubt, OEM is the best option when possible. However, the "ONLY OEM HERE IS A LINK" claims seem quite anecdotal. Yes, if you buy a shady LBJ for $15 from amazon/ebay, may God have mercy on you; however, there are other reputable brands. No mainstream automotive parts company wants to design and manufacture a product that will kill its consumers. That is bad buisness.
My biggest reason for this rant is availability. Where I live, OEM LBJs cost in the neighborhood of $400 CAD for one. I cannot justify putting that in my ~$2500 CAD 4Runner and have opted for other brands (namely ACDelco Professional line). If you opt for a reputable brand and are still concerned, check for end play as per the service manual every oil change as susggested by other members.
So when this topic is innevitably brought up again for the 356th time, commenting "ONLY OEM" may be logical for my friends south of the border, but consider adding other constructive thoughts/facts lest there be a lowly Canadian listening in and buying OEM means remortgaging the house.
As an aside, if you are unfortunate enough to have one of yours fail, feel free to message me pics. I don't know what I will be able to determine just from looking at it, but maybe I could see something of value for the community's sake.
I'm running 555 purchased from Lowrange about 6 months ago. However my truck isn't a DD. These LBJs only have 1200 miles on them in that time frame but have been fine so far and still smooth movement.
Hey fellow Canadian,
Check out these guys, I order all my major purchases from them. Shipping takes a week or two so plan accordingly. How long have you been here and why didn't you just ask?? We could have saved you some hard feelings and a lot of typing.
1999 Toyota 4Runner LUXURY(-0008),LIMITED(0008-) 3400CC EFI, AUTOMATIC 4-SPEED Joint assembly, lower ball, front left. Joint, ball. Joint, ball - 4334039465 | Toyota Parts Direct, London ON
$172.68 per side in Canada in Canadian dollars. I have just saved you $454.64 and now the AC delcos don't look like such a bargain.
Or pick up your major purchases in the US next time you are down, about $110 US per side. I have a new spare set in my parts bin for future use.
I feel OEM is worth the premium but that is my experience and my opinion only. I look forward to your future input, maybe they are as good as OEM but I'm not going to try myself.
No hard feelings at all! You made some great observations in your first post (edit: mistook another comment as yours). My comment was just to highlight some other possible reasons for the low-hour ball joint failures people have experienced with after-market parts.
Thanks for the link, though. I have come across that website before and nearly ordered the ball joints from them. The premium line options from Rockauto with a known reputation are just too hard to ignore for half the price. If I notice issues with my ACDelco LBJs, I will be sure to say so.
Well if install error can be a reason for failure. Looks to be a simple bolt on process. What exactly is the proper way to install these?
Not my intent to discourage people from repairing their own vehicle. Workmanship issues are a fact of life. Triple check your fasteners, use torque specs, clean mating surfaces/fasteners, etc. Follow walkthroughs on this site while supplementing with the factory service manual to minimize that risk.
the install error likely comes from over torquing the bolts, I remember seeing at least one post about bolt failure on the lower ball joints. another good reason not to take it to some random shop that will tighten them to the point of breaking with an impact
Good luck EVER getting that universally accepted as a cause on this forum.
I just fired off an email to Lowrange. I replaced everything on the front end last year, July 2019, and somehow I missed the issue with 555 labeled parts. I bought from Lowrange and they were advertised as OEM Japanese. It’s been just over a year and the outer tie rods and LBJ’s are rusted to crap. Luckily, I only have about 5K miles on them, but I’m going to pull them and get factory unless Lowrange has a good explanation and the rust is superficial.
BTW, I live in Austin, TX. No beach trips or salt on the road.
Keep me posted. Mine are rusty too. It appears superficial though
Is it true OEM LBJ’s still have “555” marked on them? Pretty sure I read that somewhere. Shop I took it to was an employee of my father’s way back in the day. I insisted on OEM. And paid for that. Upon picking truck up he insisted LBJ OTRE and End links were all OEM. Truck was there over weekend so I assumed he went to Toyota dealership for parts. I told him about the importance of going OEM in these trucks and the LBJ failure thing. But I remember seeing ‘555’ stamped on them after install and him mentioning greasing somewhere before I left??? Hasn’t been a year and there’s a lot of surface rust and I’m in SF Bay Area. I provided part numbers and everything. It was last second thing, dad was bringing his Mercedes there for other work and said he’d cover my stuff too. Or else I would have ordered parts myself and done it at another time. $500 was initially my cost including labor. But of course my dad insisted on a huge tip for both cars afterwards.
Anyway if there’s something to look for to know for sure, please let a brother know! I’m lifting it soon and will be doing light off-roading and want to know. I would also have a bone to pick with this guy.
I’m in SF as well, not 100% sure but I don’t think 555 is stamped on the oem stuff.. OEM doesn’t haven’t a zerk fitting to put grease into also. Lets see what others say. Honestly at 500$ I’d be surprised if they were OEM, 200-300$ for parts 200$ for labor/overhead? Should be higher labor cost IMO.
Cpn2mss
