Best place for ignition switched power
Rbates1
Where is the best place to find ignition switched power in the maplight area? I dont want 24/7 power. Trying to hardwire my gps and all the googling ive done brings up decades old diagrams.
I wired my light bar to the fuse box to the left of the steering column. Those fuses only power on when the ignition switch is turned to the "on" position, otherwise they get no power. I didn't want a constant draw from the battery which is why I just chose an empty slot there
Sent from my MHA-L29 using Tapatalk
First question you really want to answer is “What is the amp draw of the GPS unit?”
You could just use the map light circuit itself but I would make sure you don’t exceed the design limits of that circuit.
Map light circuits are generally always on, so you could just get a fuse tap off the accessory circuit which is ignition controlled and run the wiring up the pillar to where you want it.
I believe the step down says 5v. Not sure about amperage.
But then again the maplight always has power. Meaning I'd have to manually turn the gps off and on every single time. That's what I'm trying to avoid. Looks like I'll just tap the fuse box and fish a wire up to the mirror.
cremebrulady
