Best rattle can to match Cement gray..rustolium...krylon?
chrissurfr
Hey guys!
So my c4 sliders came in.
After much pondering on line-x, powder coat or rattle can...it seems that rattle can is the best option.
With that said, I would like to color match them to cement gray if I can.
Also, what is the best way to add some texture?
Has anyone tried this? Any tips would be appreciated.
Chris
I used Rust-Oleum hammered black (textured) on my FJ sliders and it worked great, easy to touch up. I cleaned with acetone and made sure it had a good primer coat then rattled away. I know they also make a gray.
If you want them to match, take them to a decent body shop and have them sprayed professionally. The cement has a metallic in it that you are just not going to find in even good hardware store paint.
IMO they're going to look goofy matched though. I'd just go with black. And don't do bed liner and especially not linex. Sliders are supposed to do just that, slide. Any sort of textured finish will just peel off as soon as you drag them across a rock or tree.
erinobr2000
