best spacer lift to bring front level
Hakabo
I have an 08 urban runner - from what i have read i have to use the spacer lift since i have xreas. i dont want to do anything except lift the front to level with the rear, or at least closer to level.
Which spacer do i need? Is there a major difference between brands quality wise?
If you want to keep the Xreas, a strut spacer would be the easiest. The siZe you'd need would depend on the wear of your rear coils which could vary depending on mileage and usage. Daystar makes a urethane strut spacer if you need about 2.25-2.5" to level it. If you need less, possibly a coil spacer from Toytec or other brand would suffice but coil spacers will be a little more involved as you will have to install the spacer inside the strut assembly.
Quality wise as far as a spacer for everyday driving if you go with any major brand you'll be fine for the most part. Ive yet to see even a urethane spacer fail.
charlesz
