Best way to add ground clearance...
netling
So I'm looking at getting my 4Runner (doesn't have a name yet) lifted but what I am ultimately wanting is to increase the ground clearance a little. What is the best way of doing this? I'm completely new to the 4Runner world, for that matter I haven't owned a truck since the 90's! So I'm ignorant to the best solution.
I know rim and tires will increase the clearance but I also know that the wrong tires can rub and damage the fender well. With that said, what tires can a 4Runner handle without issues?
What other solutions are there? I'm only looking for 2" more.
Thanks!
Charles
The Daystar spacer lift will be your cheapest choice. I have had mine on for 8 years of off road in the desert and it works just fine.
Thanks!
Charles
Here is a helpful thread for tire fitment: http://www.toyota-4runner.org/5th-gen-t4rs/156378-5th-gen-tire-fitment-guide.html#post1550444
If you actually want a functional lift, your best cheapest solution would be getting a set of Bilstein 5100s front and rear; and raising the front spring perches up to the desired height (and possibly also adding a rear spring spacer).
Also, maybe you can sit down and flip through this entire thread to see what catches your eye, since everyone's taste differs: http://www.toyota-4runner.org/5th-gen-t4rs/65893-post-your-lifted-pix-here.html
That's exactly what I did, and then selected my components based on that.
Finally, there's of course this tread: http://www.toyota-4runner.org/5th-gen-t4rs/161466-5th-gen-shocks-springs-technical-selection.html
There's tons of information about this very topic in this forum if you just spend some time and search :)
What he said ^. Also, welcome to the forum. You'd be amazed by how helpful everyone is and how much information this community shares.
Let us know when you pull the trigger on a 4Runner!
Best way to add ground clearance is with bigger tires. Best way to fit bigger tires is with a lift. Best way to add a lift is to determine your needs/wants. Best way to determine your needs/wants is to come up with a budget. Once you decide your needs and wants and know your budget you can choose your lift. Then choose your tires. Then add ground clearance :)
Spot on
And take off your running boards if they are on there. Stupid running boards always hit everything. I swear you gain 3 or 4 inches on an sr5 or limited. Pre 2014 that is. You didn't say new or old
Thanks ALL
Wow, many thank you's to all of you! I will start looking into the various options.
What I find amazing is when I a "big" truck with huge wheels and 4-5 feet to get in the cabin but no more actual clearance the the transfer case of 8-9 inches, see here. It's makes me laugh. :laugh:
Anyway, I will start looking into my funds, what others have done and get moving.
As for my 4R, it's a 2013 SR5 Premium. I haven't done anything to it yet but I have ordered running boards, I know against some advise here but /she/ wanted them. :noidea: Ok, and I'm a short bastard! :behindsofa:
From what I'm seeing, I can put as much into accessories as the 4R! :wink2:
Please continue the feedback and again thanks!
increasedc
