Biggest and best battery
Yes, the height adapter is all you need.
Also, the above mentioned coupon code through 4WP appears to have expired. FYI
Perfect, thanks for the info! Got it all ordered. Have the ARB fridge on order and would rather just address any potential power problems right away.
Sweet, that battery will be plenty.
So I'm also looking at the other item you shared: https://www.amazon.com/CTEK-56-353-12-Volt-Battery-Charger/dp/B000FRLO9Y
Reading through the description and what not I'm still a little lost. I understand it's a battery charger, but looking at the pictures I don't quite understand what it plugs into? I would have "originally" assumed a standard wall outlet, but I'm not really seeing many indications of that on the description.
Can you please explain how it works and what setting you use the charger on? Just want to make sure I at least understand what I'm buying, prior to pulling the trigger.
Yes, it plugs into a wall outlet. Read through the description from the manufacturer on the Amazon listing. It gives a very detailed description of this charger's capabilities. It's a battery charger and it maintains your battery. This one in particular maintains a high enough voltage in float mode to keep up with the Odyssey batteries. I just keep it on the "snowflake" setting, plug it in, and forget about it. You could keep this on your battery for months if you wanted to and it will not hurt it. It is fully automatic so you put it on the desired mode and the charger takes over. I usually throw it on once every week or two to top the battery off.
One cool feature is the supply mode. You can hook it up to your battery cables while you change out your battery so you don't lose any of your presets on your radio or any other settings you might lose while disconnecting a battery.
I definitely recommend this item to keep your odyssey in top shape.
For someone who does not have anything like a fridge or aux lights, would this be necessary or just a good to have?
If you are running bone stock on your electrical system, I personally wouldn't spend the change on a high dollar battery like that. I do think it is a good idea to always keep a good quality lithium jump pack on hand though
I use to upgrade my batteries after living in las vegas, but that was before the invention of a jump pack. These days, I just carry around a jump pack and function check it once a month or so.
No, it would be a complete waste of money
Or worse.
I have spent many dozens of hours and many hundreds of dollars fixing cracks in my driver's side fender and trying different battery tie downs, only to have to relocate the battery to the passenger side and buy a group 34 size. My fully functional 31M sits in the corner of my garage on a battery tender.
Northstar also makes the X2 batteries at Batteries Plus
I just bought this battery:
Duracell Ultra Platinum 31 after rebates and coupons and taxes and core charges it worked out to $240. its also american made, made by East Penn-Deka.
I purchased a NOCO GenM1 on-board charger for it. The regular NOCO chargers charged at too high of a voltage, but the on-board chargers are 14.4V which is within spec. I have the install and operations manual from East Penn for this battery if anyone wants it. I spoke with East Penn and they recommended Clore Automotive; i contacted Clore because their website didn't show technical specs for their chargers and they just replied "check the website." I contacted NOCO, they reviewed the O&M manual and said the GenM1 would work well.
I bought this tray because it was amazon prime and i can have it tomorrow: https://www.amazon.com/gp/product/B002ZMKJWU/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 none of the local auto parts stores had a 13" metal tray and the basic $10 trays online wouldn't be here to next week.
Hey did you go with the 4amp or the 10amp version, and what are your impressions of the unit after some use?
Or worse.
you can buy a battery box, like a arcpak or a cheapo batterybox for fishing boats, and move it to the back of the truck, thats what I did for my 31M, so it doesn't got to waste.
I got the 4A version (NOCO Gen M1) and am very happy with it.
For me when I'm charging I'm usually parking somewhere at least overnight, so 4A is plenty to fully charge my battery during that time. It is also more than enough to manage the load of my fridge, so for example if I'm going to be out of town or something I leave the charger plugged in so i don't have to worry about emptying out the fridge or cleaning it to prevent mildew (with temps in the 90's i get about 1.5 days from the battery with the fridge shutoff on high and up to about 3 days on medium, and i tend to leave it on high for day to day use and only use medium when camping)
If you need something that will charge in an afternoon or something, get the 10A
(For NOCO chargers only the on-board chargers had acceptable voltages for my battery, DEKA reviewed the other NOCO chargers and said not to use them. The on-board chargers are in-spec though)
I considered doing that, but my 4runner is already at 3 tons, so I'm trying to avoid extra weight.
Just upgraded my OEM Panasonic to an Odyssey 34R-PC1500T. Got it through 4WheelParts.com for about $220. Used coupon code CC5OFF FOR 5% off. Odyssey Batteries - Odyssey Batteries Extreme Series, Group 34R, 880 CCA, Top Post - 34R-PC1500T | 4WheelParts.com
To get it to fit perfectly with the stock hold down, I had to get the Odyssey height adapter for the Group 34: Spacer for Group 34 batteries*| ODYSSEY Batteries
Also Purchased this CTEK charger to keep it in top shape. This charger was recommended by [MENTION=124732]LawnDart[/MENTION] and it is on Odyssey's recommended charger list.
CTEK MULTI 7002 12 Volt Battery Charger
How often do you need to connect the CTEK on a group 34?
I can't give you a definite answer because I don't know. What I can tell you is I throw mine on the CTEK once every two weeks on average. I usually let it stay on there at least overnight, sometimes for two full days if I'm not going to be driving the 4Runner. From what I've read that seems to be sufficient, but I guess time will tell.
Take care.
Coupon code for odyssey
Starting today until November 14 I think
20% off at the odyssey site. Use SEMA2017 in all caps
No tax no shipping
Got the 34rpc1500t and the tray for $241 to my door.
I have been running a XS Power D3100 in the factory spot and a XS Power D3400 in the passenger spot by the firewall using the Off Grid bracket. So far they have worked great, especially with the car audio products that i added.
No tax no shipping
Thank you for the discount code. I just ordered mine today. Where did you find this code? I need a new battery for my Waverunner next spring and do not want to order it now and have it set around all winter but I would like to know how to find a discount code in the spring.
Also they added $19.99 to the order for sales tax. Total came to $261.
Came up when using my phone searching for odyssey batteries. Didn't come up when using my laptop. Not much help but try mobile and desktop I guess.
Froogle.com sort by price is good too
Thanks for the tip!
No tax no shipping
I appreciate all of the comments advising caution on the "too heavy" 31 size. I went with the Odyssey 34R-PC1500T, with spacer, $241 delivered. And, 6 months to pay using Paypal!
NZDZRT
erinobr2000
