97BlackAckCL
Elite Member
Here's mine installed, I had the rails powder coated, and replaced the stock silver end caps with stock Toyota OEM black end caps
I'd like to get some expertise here. I just had my roof rails powdercoated, it looks like the seals that bolt down into the roof may have had some sort of sealant. I didn't reapply any and now I'm concerned about leaks. Anybody have advice/experience with this?
Thanks, that gives me some peace of mind!i've taken mine off and on a few times over the last year, using only the OEM hardware to put back on-- never added sealant and never had any leaking problems. it has rained really heavy several times, sat under melting snow, car washes, etc... no problems
the bolts have rubber gaskets on them, but maybe put some sealant on the bolt threads for some peace of mind.. though i didn't even do that TBH
Actually I did use red threadlocker on the bolts like it came originally although I don't really know if that was necessary. I was surprised to see it given it wasn't that extremely tight.
I've read to use sealant (black rtv for example) in the bolt holes and around the white tubes. There was a picture somewhere around here. That's what I'll be doing this weekend. Trying to figure out what type of paint to use. Hoping for a satin black plastic paint for the caps and semi gloss black type of paint for the rails.
I was going to scuff the plastic up, clean it well with rubbing alcohol and then use krylon fusion. I ended up buying TRD endcaps and getting the rails powdercoated.
I'm hoping the OEM Toyota black rails will be reasonably priced and I'll get a set of those. Hard to beat the convenience and quality of a Toyota part showing up on the doorstep.
You may be right but that would be insane when we already have the rails. I just had mine powdercoated for $100. I had to call a couple shops, the first one wanted $175.if I had to ballpark it... 1300-1500
Do you think Powder Coating is more durable than paint? I was thinking about getting my powder coated. Looks great BTW.:thumb: Thanks
