Magnetic4R
Direct fit, no modification needed, just specify that you have a limited when ordering
Thanks! I see them on the website now.
Did you originally have the OEM LE running boards? I just want to compare how much higher the sliders sit vs the OEM boards. I feel that the LE running boards hang very low and would like to get a bit more clearance while still having a small step for the kids and the wife.
My other option (although more expensive) would be to replace the rocker panels with TE rocker panels and buy the TE sliders. I assume that would increase the ground clearance even more.
The passenger side went on much easier (as is typically the case), but it too, was pressing against the mud flap and seemed to be a bit farther forward. However, I was unable to thread the upper rear bolt into the frame. At first I thought it was just the alignment of the slider bracket hole that was making it difficult. But I ended up taking the slider off and still can't get a bolt threaded in that hole. Tried multiple bolts and the bolts thread fine into any other hole in the frame. Since I don't have any metric taps and very little metric hardware, I eventually gave up. Does anyone know what size tap I need for that?
This is the first time in a few years that I spent any time under a vehicle, I don't remember cement being that hard! Or maybe I'm just getting old :nod:
Can you tell by looking at it that that problem nut is actually the same thread pitch as the others? I've had situations on my '14 where the holes and the nuts from one side to the other are not necessarily in the same place or the same size!
Anyway if it is obviously the same nut as the others, I'd just truck to the tool store with the bolt in tow and match up a tap for it there... While your there buy a bolt/nut pitch gaugeThey come in handy a lot
Attempted to install my OPOR sliders last night. Things could have gone better. One slider is installed, but I may be pulling it back off tonight.
The slider is currently pressing against the front mud flap and causing it to deform slightly. It looks like the slider needs to be about 1/2/" back. This is on the driver's side.
It is also not very level, but I think that can be adjusted but I did try.
I bought OEM mudflaps for the LE but was trying to figure out how to install the front one in conjuction with the miniflaps that came with the LE ? Seems like there would be a gap in the well if I remove the miniflaps and only put on the mudflaps? Do you need to trim that miniflap or is there a better solution I am missing? Thanks!
I did not actually install the front mudflaps but I will recheck once I get the nasty stuff off the truck! The miniflap does not do much to keep snow off the running board. Can you take a pic of your frontmudguard and the wheel well?
I did not actually install the front mudflaps but I will recheck once I get the nasty stuff off the truck! The miniflap does not do much to keep snow off the running board. Can you take a pic of your frontmudguard and the wheel well? If I remember, the miniflap was attached higher than the front mudflap so if I thought if I removed it, there will be a gap behind it unless the mudflap was redesigned for 2014 Limited and I got the wrong one; I think I got one to fit 2010-2013 Limiteds at the time - I just assumed it would also fit the 2014.
Is it the picture or is that slider really pitched upward front to rear?
So, this happened sometime last night.
I noticed this after cleaning all the egg off the tailgate, window, spoiler, bumper. It's right below the window. I don't think it's going to just buff out.
There are also streaks still visible where the egg ran down the tailgate and bumper.
Maybe that's what the dog was barking at last night....
