Brake Light Issues
sagedd13
I have an 86 4Runner and the brake lights will not go off so I have to disconnect the battery to keep it from draining. What is the issue, why won't the brake lights go off?
Sounds like you Brake Light Switch under the dash that is attached to your brake pedal might be stuck.
Check by pulling up (towards you) on the pedal to see if they go out. If so then the switch is shot.
AndiGarage
