BrianSD_42
With that tape is there any negative effects like heat build up that may be detrimental to the life of the bulb?
If you are referring g to putting tape on the bulb, don't do it. That was a terrible idea and it didn't work out.
Whooooa lol yea I was talking around the projector? You put tape on the actual bulb?
Hey Brian,
In your parts list you have an extra set of headlights from Ebay. Is this 100% necessary? If so, why?
Thanks in advance.
Hey Brian,
I got in on the Tacomaworld group buy last week and will be performing my retrofit next month. Pretty dang excited.
Thanks in advance.
Hi,
If you have the original 98 lenses then you will want to buy a set of TYC from eBay for $75 and use the clear lenses.
As per my instructions in original post, you will want to bake the light assembly and remove the clear (TYC) lenses. Then wrap the 2 clear lenses in something protective to put with the rest of the parts. give it all to the guy doing the retro and tell to just put the clear lenses on when sealing them up during the final step.
You will just throw the TYC housings away or put on CL. Don't try to use them instead of the stock housings, I assume someone is going to do the sanding and painting so your old stock housings will be like new.
It is important to understand that the quality of the plastic (specifically the part that adjusts) on the TYC/eBay lights is completely inferior and crap. But the glass is just fine.
Thank you for clarifying this, and that's a great idea (and much cheaper than buying OEM)
At first my harness did not seem to be working correctly but after I called them I realized I had it hooked up wrong.
will the output be really noticeably better that then Mini h1 6.0.
I am thinking of picking up some FXR 3" today for the black friday price.
This is my first retrofit, will the output be really noticeably better that then Mini h1 6.0. (I already have matsushita gen 3 ballasts and some philips bulbs)
I guess I am wondering if its worth the added trouble and potential mistakes involved with this installation.
Also does anyone have experience with the multi colored halo's? Are they any good?
I cant make up my mind between amber and white. If I go with the Mini's I will get the smoked shrouds and with the Fxr's I will go with gatling or g37r.
So it has been 1 year since did this mod and some dust has gotten inside the light housings.
I believe the reason is because the default breathing tubes (2) let in dust.
I have now fixed this so no dust can get in.
Here is the fix:
1. Bake lights (every time), open up and clean inside, wipe out the dust
2. Put the glass back on and re-bake, put on the metal clips etc
3. Add silicone sealant around the outside of the light and on the back around where the bulb is. This may be overkill but I don't want to do this a 3rd time.
4. Pull off the 2 rubber breathing tubes on the back of the light
5. Fill one of the tubes PARTIALY with silicone sealant, , enough to block any air, let it dry.
6. Upgrade the second tube with extended hose and filter
7. Add about 6-8" of Fish Tank Air Hose ($6 Petsmart) and glued it to the small breathing rubber. The idea is not to block the airway at all when doing this.
8. Add an air filter into the fish tank hose. I bought Cheese Cloth from Michaels (Arts & Crafts Store) and cut out a 1" by 2" piece and then twisted it up and shoved it in the tube.
9. Test that you can push (blow) air through the hose with the filter installed, better make sure the silicone had a few hours to dry!
10. Once it is dried, install onto the light as such.
